![]() | Home > Maintenance & Modifications > What’s this part? |
Hello all. What is the pipe (NOT the sensor attached to the pipe) highlighted by the Number 4? I have a lot of oil sprayed around here and cannot work out where it is coming from. If anyone has an idea where the oil might be spraying from (seems to be underneath) that would be useful too.
![]() ![]() Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
MarkGB Member Since: 17 Feb 2019 Location: Midlands Posts: 2 ![]() ![]() ![]() |
Hi, it looks like it's the EGR valve tube:
https://www.lrworkshop.com/diagrams/land-r...ipes_45015 |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
More than likely it is the vacuum pump. It's in front of the area you've highlighted so a good chance the oils made its way back there.
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
My defender is in on tuesday for work on it but whist there the machanic is going to look at mine as i have this prob i hope rather than something more expensive but what annoys me is land rover or after market is silly money compared to ford ie
https://cdn.e-motiveonline.com/transitparts/images/logo.png |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17983 ![]() ![]() ![]() |
Pipe number 4 in that picture is the extension to the inlet manifold that connects the manifold to the hose from the intercooler, the manifold to the EGR, and also holds the MAP sensor. It is common for it to be gungy. Oil on the outside may be from the vacuum pump, oil inside will have come from the breather system or turbo via the intercooler.
Thanking you all. Will have a look tomorrow.
![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
