![]() | Home > Td5 > Down on power/not boosting... |
| Paul1275s Member Since: 21 Apr 2019 Location: East Sussex Posts: 80
Ok, gonna check red ecu plug and look at cat. 2003 Defender 110 TD5 SW
2003 Caterham 7 2006 Mini Cooper GP |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3553
The engine should run OK with the MAF unit disconnected, it won’t be at its best but will perform fairly well (my 110 TD5 will still do 70mph)
| fred1922 Member Since: 04 Jun 2018 Location: Bomaderry Posts: 1
It is difficult to see if wastegate shaft is moving without removing cover guard, two pop rivets. If car had been unused for some time, it would certainly be worth more attention.
| gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 654
What fuel pressure are you getting? Mine was dog slow and wouldnt boost when the high pressure stage of the fuel pump died. When was the fuel filter last changed? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r |
Not sure how to measure, I assume I'd have to take it to a garage? I'd imagine the filter is way overdue going on the rest of the previous maintenance! Red plug was full of oil, I've given it a damn good wash out with electrolube, I think it'll need a few more goes... 2003 Defender 110 TD5 SW
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
Good call on fuel filter.
Start with the easy stuff first. Air and fuel filter. |
| michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65
If the red plug has oil in it, then you should chance the injector harness as that's were it leaks from, and also clean out the whole loom from the harness down to the red plug. 2002 110 TD5 White 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
| All times are GMT |
