Home > Td5 > TD5 - Strange starting problem
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Over the last few months my 110 has developed a strange starting problem.
This is what's happening;
- Turn ignition on
- All normal lights come on. Temperature guage normal, fuel pump running
- When glow plugs go off, turn to start
- nothing, just a click
- turn off
- repeat the above and it starts
If you remove the key from the ignition barrel and try again it won't start but just goes click until the second time of trying.
Occasionally it's takes two or more cycles before it tries to start.
Things I have tried so far;
- replaced both yellow relays under the drivers seat
- cleaned up the earch point under the drivers seat
- cleaned up te earth on chassis and gearbox
My next thought is to check the ignition barrel, but I'm not sure what I'm looking for or if there are other tests I can try.
Thank you for reading.
Post #774682 24th May 2019 11:06am
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
sounds like a starter issue and it might need a rebuild to solve it. it will get worse and it will stop starting eventually. The defender has migrated, leaving the owner behind.
Post #774683 24th May 2019 11:20am
gilarion
Sounds like a dodgy starter motor solenoid. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #774689 24th May 2019 12:24pm
Paddie42
Thank you.
I change the solenoid contacts five years ago. Worth having a look to see if they need replacing again.
Post #774690 24th May 2019 12:29pm
landy andy
Yep. Agree. Starter.
Post #774696 24th May 2019 1:11pm
Defender Fun
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Hi
Yes definitely the starter, I had the exact same problem with the 110 2005 td5 I had, it got very bad, so I replaced the starter with a new Bearmach one in Feb. Problem sorted.
Kind regards
Post #774704 24th May 2019 1:56pm
Paddie42
Thank you all for your help.
New start motor solenoid kit ordered from Amazon (https://www.amazon.co.uk/Diesel-Starter-Re...amp;sr=8-4).
Depending on when it arrives tomorrow I'll get it installed and update this thread.
Thumbs Up
Post #774706 24th May 2019 2:00pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
Starter
Replace starter solenoid and connections , think you can still buy kit from most suppliers for around £50
https://www.paddockspares.com/red-bison-ho...l-kit.html Have fun be happy
Post #774748 24th May 2019 6:32pm
