![]() | Home > Wheels & Tyres > Tyres rubbing! |
spam242 Member Since: 06 Aug 2016 Location: west sussex Posts: 73 ![]() ![]() |
A friend of mine has just fitted some 35 12.50 15’s to his 1996 90 and is now suffering from some arch rubbing even after cutting down a bit. Has anyone fitted these tyres before and if so how did you over come the rubbing?
![]() Click image to enlarge ![]() Click image to enlarge |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
It already has a lift on it.You can see the cranked arms in the pic.
Cut the arches. ![]() ![]() Click image to enlarge |
Yeah it’s running a 2 inch lift, already trimmed the arches. Is the next step cutting the body work?
Where is it rubbing.Back/front,on full lock???
Mine does'nt rub since cutting the arches & adjusting the steering stops. I have 2" lift,& full Gwyn Llewis suspension set up,+5" OME shocks. Marc |
Ndamico Member Since: 03 Apr 2019 Location: Canada Posts: 52 ![]() ![]() ![]() |
Which OME springs did you go with? 04 110 TD5
