Home > In Car Electronics > Recommend a round dashboard USB socket
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
My current one is causing interference with the radio so looking for suggestions for a better replacement. There are loads on ebay/ amazon but prefer one recommended so I don't have the same issue again.
Maybe with a battery volt meter in?
If it had a volt meter in, does the wiring need changing or will it still show the battery voltage? The existing is wired from the lighter socket.
thanks.
Post #774538 23rd May 2019 11:28am
excossack
Can I ask, which one do you have the causes interference? I have the same with my dual USB Bluesea one. With a USB lead plugged in and a phone at the other ends, wipes out FM. Unplug phone and all good. Tried various USB cables. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #774542 23rd May 2019 11:47am
Bluest
It might be worth trying a USB cable with a ferrite sleeve. If you haven’t got one you can get the sleeves on their own on Ebay 2007 110 TDCi Station Wagon XS
Post #774545 23rd May 2019 12:52pm
Post #774549 23rd May 2019 1:15pm
PCM
I second the blue sea ones.
Had a cheapy from fleabay and it caused all sorts of FM interference
Blue sea do a 4.8A fast charge one or a standard 2.1A one.
https://www.mudstuff.co.uk/fast-usb-socket.html
or the cheaper
https://www.4x4overlander.com/product/blue-sea-dual-usb-socket-2/
Both work really well and have no interference for me.
Post #774628 23rd May 2019 11:29pm
williamthedog
Another +1for bluesea Thumbs Up
Post #774637 24th May 2019 3:55am
