Home > My Defender > Hello again!
Stiff1
Hello again!
So after the traumatic sale of the 110 about 18months ago on condition of getting first refusal in future... I got it back last week.
Smile has become a fixed feature.
So, things to do... a lot of TLC so a little advice please.
Since it has been away a lot of salting/ oxidation has occurred so a lot of T cutting has that largely dealt with that.
Underside all good so just a little topping up of protection there.
Strange collection of "stone chips" on bulk head "fake flaps"
Corrosion on rear 1/4 mid seam... ideas on correction please
Give it a good service.
Lots of corrosion to various blots - Not sure I want to go down the SS route due to reaction and also a little bling against the black. Where, other than the dealers do you get standard bolt sets, poss with security heads (galv)
NAS step needs a blast and re powder coating.
New wing mirror arms on order
A few door seal need replacing, are they all the same otherwise recommendations please (saw these https://www.ebay.co.uk/itm/Land-Rover-Defe...tupt=true)
Clear lenses yellowed, tried one of the restoring polishes... got bored very quickly so replacements it is. Toyed with LED previously but not keen on the "bauble" look (no offence).
One rear seat would not fold up, disconnected cable at fault, sorted now.
Continue with sound deadening.
Front seat upgrade at some point.
Just a few thoughts for now.
Post #774499 22nd May 2019 11:54pm
Procta
welcome back, a bit of a clean up but nothing bad. Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #774502 23rd May 2019 5:57am
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Good to see you've got it back.
Is that a Maxxraxx mount fitted on the tow bar?
Re the bolts, I would have thought any decent fixings supplier locally should be able to help you there, especially if your looking for something with a different to standard head. You'd be better taking them the originals as patterns though.
Looks like a decent little project Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #774517 23rd May 2019 8:53am
Stiff1
Thanks for the comments so far.
Re. the bike rack, yes it is for the Maxxraxx. Fitted it under my previous ownership, even had an extra fixing loop welded onto roof rack when I was restoring that to secure the top strap, great bit of kit.
Post #774518 23rd May 2019 9:04am
Stiff1
My main concern is corrosion on the rear between tub and roof and weather these will need separating?
And also the strange vibration from underneath at 70mph, not that it does that speed often. Thinking wheel balancing then poss prop shaft. ..
Post #774519 23rd May 2019 9:09am
L110CDL
Great you got her back back and welcome back to Thumbs Up
As for those chips on the fake vents, they look like that someone has been using the angle grinder not to far away from the landy to me Rolling Eyes Clayton.
Keeper.
Post #775218 27th May 2019 8:41pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Mine has a similar issue on the fake vents. I’m thinking just to get the local paint shop to knock it back and a quick localised respray.
Post #775231 27th May 2019 10:11pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Def genuine door seals, yes they cost more but you will only end up spending twice if you get after market ones.
Post #775243 27th May 2019 10:48pm
Greadh
United Kingdom 2013 Defender 110 Puma 2.2 USW Santorini Black
you could try some "fall out remover" on the bulkhead, it could remove the streaks and and iron deposits left on the paint, will allow you to see the actual damage to paint work then - it it is someone grinding near the car might even find a cut back with a heavy compound and a polish and you wont notice them. Might need a few goes with the fall out remover, keep going until it stops turning purple...... worst case it should remove the streaks for now.
Post #776474 7th Jun 2019 10:47am
