Home > Puma (Tdci) > Clonkly noises
RobKeay
Clonkly noises
My father in laws 90 tdci makes a clonking noise. The noise happens when the clutch is depressed and you coast upto the junction.
Any ideas?
Post #77447 23rd Jun 2011 9:16pm
Grockle
pos back lash in the propshafts etc as the wheels are turning the shafts and not vice versa. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #77482 24th Jun 2011 8:10am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Hand brake incorrectly adjusted is common as well. So next time as you coast to a stop gently (i mean gently) with the button pressed in drag the hand brake and see if the noise disappears. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #77494 24th Jun 2011 8:32am
RobKeay
I thought prop or handbrake. Was worried it might be clutch. I'll get him to try the handbrake.
Post #77502 24th Jun 2011 9:12am
Nellie
United Kingdom 2011 Defender 110 Puma 2.4 USW Baltic Blue
We have the same noise under the same conditions - will also try the handbrake Wink
Post #77558 24th Jun 2011 3:10pm
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Seems a common problem, on newish defenders with the handbrake shoes binding, once it has got a little warm. There are quite a few posts about this, and the symptoms sound exactly the same. Thumbs Up
Post #77599 24th Jun 2011 6:33pm
Blaserman
England 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Mines been doing that!
So far its had 3 rear diffs, a new handbrake drum, a new clutch, 2 rear half shafts and 2 new drive flanges.
Its almost cured!!!!!
When coasting pull the handbrake up slightly if you hear a machine gun style knocking the handbrake wants backing off a bit. Failing that the clutch seemed to be the main problem on mine.
Post #78466 30th Jun 2011 8:41am
