Home > Puma (Tdci) > Surging
Page 1 of 3 123>
22900013A
Surging
Am I just imagining things, or does my 110 sometimes drive as though I am lifting my foot on and off the gas pedal? Its very slight, but noticeable enough, even the mrs noticed it today, seems to only happen at low speeds. Its done this maybe 2 or 3 times now. Has anyone else experienced this? Rev counter is not moving (ie its not bouncing up and down) so I don't think the engine is literally revving up or anything, just feels as though its pulling, then stops, then pulls again...we ignore the speedo as its stuffed due to the tachograph.
Or is it just me?
Thumbs Up 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #77424 23rd Jun 2011 8:29pm
sounds like anti-stall ... pre-programmed
Post #77445 23rd Jun 2011 9:12pm
22900013A
Oh right, why is that kicking in then when I'm driving along? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #77456 23rd Jun 2011 10:09pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
What RPM was the engine at? it sounds like anti stall or idle jack
Jack
Post #77459 23rd Jun 2011 10:26pm
22900013A
I was doing about 25-30mph in 4th, so maybe about 1200 rpm? 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #77472 24th Jun 2011 6:55am
Caterham
sorry to jump in but could anyone shed a little more light on this anti stall - I know what it is and what its supposed to do but a) I thought this was a low ratio thing and b) at 1200 rpm......?
I presume this is a completely electronic thing and doesnt cause intermittent problems etc? if a problem then is it a re-map?
Post #77473 24th Jun 2011 7:18am
Zagato
Need to get your revs up by the sound of it - I tend to keep mine between 1500 - 2000 rpm!
From LR - "And to cope with difficult progress when the engine is working hard at low speed, say 1000 RPM, the anti-stall device intelligently adjusts the fuel required by the engine".
Have you got the hang of the gears yet or is it still clunking?
Post #77474 24th Jun 2011 7:19am
22900013A
I have got the hang of the gears, but they do clunk sometimes...I just accept it to be honest. I do tend to let the engine pull the vehicle along at low speeds, which could be why the anti-stall might kick in, but its still at 1500rpm or so... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #77552 24th Jun 2011 2:13pm
jst
if you put it in high 1st and pull away with a load - ie uphill or applying the brake or something similar to invoke the antistall are the symptoms the same as what you describe at speed in 4th? does it do it in all the gears?
dont touch the accelerator pedal when doing the above.
anti stall works in all gears hi and low
idle jack is low range 1st specific. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #77555 24th Jun 2011 2:33pm
22900013A
It could just be the amount of play in the drive train, our roads are bumpy...doesn't seem to do it all the time whatever it is... 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #77607 24th Jun 2011 6:53pm
Zagato
Bumpy roads....sounds more like throttle control Confused They can lurch on and off an get into a lurching rythym if you don't steady the pedal. Ease off, stick your foot down or they used to say push your foot against the bulkhead wall whilst your foot is on the accelerator to steady it over rough ground - they actually say wedge it against the bulkhead Shocked See you in timbuktu Neutral
Post #77622 24th Jun 2011 8:04pm
xatzhs
I seem to get this jerking quite a lot... and also clunking gears. Am I just driving it like a complete rookie? (This is my first Defender) Any tips?
Post #77669 24th Jun 2011 11:20pm
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
My defender does about the same. When driving in second at about 1500-1700 rpm and easing the pressure on the pedal it sometimes raises the revs a little bit - a few times I felt I had to apply the clutch Shocked because I intended to slow down and not increasing speed. It only goes on for a a sec. or two - gotten used to it by now.
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #77683 25th Jun 2011 7:06am
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
This all sounds familure, although I can't recall where I read it, but it may be something to do with one of the fuses being blown. I think it was the brake light fuse, but can't be certain.
I'll see if I can find what I read, but it was quite while back. In the meantime, it won't take long to check your fuses.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #77691 25th Jun 2011 8:18am
22900013A
I can check the brake lights easily enough using the reflection in the house windows...
To be honest its such a subtle thing, but enough to be noticed. I think I only really noticed because a) its a brand new truck and b) I have been keeping a close eye on things due to problems with it having the tachograph in. 2011 110 USW
1969 IIA 1-Ton
1966 IIA 88"
Post #77699 25th Jun 2011 9:25am
Page 1 of 3 123>
