Home > Maintenance & Modifications > DIY wheel alignment/tracking
Zed
The internet has shown tracking done with string, tape, mop handles, bits of tube and laser gadgets.
Which method would you chaps recommend?
It needs to be idiot proof because, well, I will be doing it.
Post #773805 19th May 2019 8:23am
grafty99
In all honesty, I would pay someone to do it.
I think I payed £40 for a 4 wheel lazer alignment, it made quite a difference at the time (it was a while ago now Shocked)
However if I was doing it myself I would probably remove the front wheels and clamp two straight edges to the hubs, then measure for parallel Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #773811 19th May 2019 8:46am
Roy5695
I tried doing it myself with the measuring to the front and rear of the wheel rim. Got it close but sent it off for a proper check and it was out a little bit. The difference between many thousand miles on a set of tyres.
So in my opinion it’s much more sensible to pay someone to do it proper. Cost me £45 at an ATS place. Took them all of 15 minutes dudeto the brand new sumo bar and drag link I’d just put on. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #773815 19th May 2019 9:01am
Zed
Cheers chaps. I hear you but my tracking is out now, which I'd like to sort and in a couple of weeks I'll be doing the Gwyn Lewis drop arm sumo jobbie. Plus I wouldn't mind knowing how to do it anyway.
Post #773816 19th May 2019 9:06am
The last time I did an emergency tracking job (on a S1 about 30 years ago) all I used was a metal extending tape measure and a helper to hold the end. As far as I know it has still never been readjusted so can't have been too far out!
Post #773817 19th May 2019 9:16am
Mo Murphy
I use the string method, served me well for the last 25 years. It's quick, easy and accurate enough.
50 Shades of Pennine Grey
Post #773819 19th May 2019 9:32am
richcl
I use the string method too.
Just remember the difference between front wheel drive, rear wheel drive and all wheel drive cars when carrying out this procedure.
Post #773820 19th May 2019 9:37am
hank
I'd like to give this a go too as I have been underwhelmed when having it done "professionally" - steering wheel off centre, vehicle tracking one side or the other, unequal number of turns left and right on the steering wheel etc.. > 110 XS Double Cab
Post #773822 19th May 2019 9:45am
mactheknife
United Kingdom 2004 Defender 110 2.5 TD CSW Baltic Blue
I used two flat bars and a tape measure to get mine aligned after replacing all the track rods and ends. I got it as close to perfect as I could, but still took it to a shop to get it double checked as I had a wheel out of balance. They said I was still about 1mm out, the difference was noticeable.
The alignment check took 15 minutes and cost £15.
Post #773931 19th May 2019 11:19pm
Mies
Netherlands
String method. Was conviced fancy laser type stuff must be better until I had a pit-pass for a WEC race at Spa......even Audi was using the string method.
Post #773935 20th May 2019 1:51am
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
These are fairly useful to do the tracking with. A little limited on how much access you have but as long as you use the same height front and back will get it close.
https://www.screwfix.com/p/harris-trade-ex...gIl1_D_BwE
When you buy one SWMBO will get excited and start choosing some paint colours.
Post #773943 20th May 2019 7:38am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I use 2 aluminium pipes that fits snugly into each other. The biggest of the 2 has a diameter of about 8mm.
The inner pipe slide out telescopically and I mark on the inner pipe with permanent marker.
I measure the distance between the front rims at the rear and front on the same height. Using a straightedge to determine height but a laser can also work.
After adjusting alignment, I roll the vehicle back 2m and back to original position and remeasure.
I work on a 1mm difference between front and rear, but can't remember if it was +1 or -1mm..
A while ago I had new tires fitted and alignment done, the guy doing the alignment said I was almost spot-on.
Post #773944 20th May 2019 7:56am
v8bob
Just walking past wilko and popped in to see one of these:
https://www.wilko.com/en-uk/wilko-extending-pole-1-2m/p/0343127
Only 3 quid, not worth getting a hacksaw out to make one at that price.
Post #773987 20th May 2019 11:34am
Bluest
Ive just seem all the British Touring Car Championship teams using the string method this weekend. If it’s good enough for them... 2007 110 TDCi Station Wagon XS
Post #773990 20th May 2019 11:37am
Must set mine up... never bothered in the last 9 years/65000 miles.... be interesting to see how far out it is... probably miles out, seeing as I built the axle from various sources
Post #774008 20th May 2019 1:05pm
