Home > Maintenance & Modifications > Trailer Axles
tyrannosauROSS
United Kingdom 2006 Defender 110 Td5 CSW Chawton White
Trailer Axles
Good evening folks,
Im not sure where to post this question but I'm sure some of you knowledgable folk can answer or point me in the right direction.
I want to get a trailer but was wondering if you folks can tell me of your experiences with the different types of trailer suspension that is out there.
I love the look of the independent suspension the Australians get on their camping trailers and the solid axels on the military stuff is obviously butch but in the UK it seams that trailer suspension options are limited to the silly small rubber stuff.
I was wondering if anyone had any experience they wanted to share in terms of longevity, robustness, etc etc..
thanks
Ross
Post #773797 19th May 2019 2:13am
The 'silly small rubber stuff' has been a tried and tested system for 50-odd years that's robust and easy to maintain. Why do you think it's silly?
The type of suspension used on a trailer is dependant on it's purpose, i.e. the load it is to carry and the terrain it's to be used in. Leaf springs are simple, robust and able to cope with heavy loads but are relatively heavy themselves. More complicated, coil sprung independent systems are a solution to cope with very difficult terrain and usage such as higher speed, off-road driving. They give a much better ride over corrugations, for example. They are, relatively, more complicated and maintenance heavy but are ideal for that niche usage. Elastometal independent suspension units are smaller and lighter, which makes them ideally suited to smaller trailers to maximise their payload.
What do you want a trailer for? Darren
Post #773814 19th May 2019 8:57am
Romadog
Rubber all the way.......hate those noisy leaf sprung things Thumbs Up Thumbs Up
Post #773877 19th May 2019 3:16pm
Thon
Military leaf-sprung types are great in some ways but having owned a conventional general purpose trailer, Sankey and Penman, I would suggest that unless you have an overriding reason or desire to own an ex-Mil, the conventional trailer is likely to be the best option.
Military trailers are heavily engineered to withstand a lot of abuse and carry a reasonable payload over challenging terrain, but they also tend to be less practical for the day-to-day stuff. Things like hitches, electrics plugs, tail boards, covers are all stuff that's different on the military trailers. My Penman for example has no drop tailboard, a one piece tilt (no zips or flaps), weighs 620Kg for a payload of 1130Kg and with the hitch positioned on the X-member (where it is located ideally), cannot carry a spare wheel on the back door and still has a significant nose-down stance. Spares are expensive too and reversing a short trailer with a LWB Defender is challenging.
On the other side however the Penman tows really well (forwards) and feels as solid as a rock, and no doubt will outlast me. It also uses the same wheels and tyres as my Defender, so a puncture would be easily dealt with. Also I like it and do get to use it in its intended environment so whilst I could get away with a conventional (sensible) trailer the one I want is this one Very Happy
Post #773890 19th May 2019 4:54pm
JOW240725
My 'adventure' trailer has a torsion suspension axle apparently from military trailers. It's rated at 1800 kgs which is too high really but when heavily loaded it tows very well. James
Instagram @suffolk_rovers
Post #773893 19th May 2019 5:42pm
