![]() | Home > In Car Electronics > Heated window screens |
Peregrine_White Member Since: 05 Feb 2019 Location: North West Posts: 68 ![]() ![]() ![]() |
Perhaps look at Dan Padmore of Pace 4x4 he makes all sorts of wiring looms
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
It's a 'windscreen', it screens you from the wind, not windows.
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Mobilecentre do loom kits, a Td5/Tdci kit with factory switch and a universal one to which you can fit your own switch.
I have one of their kits in my 90. Indistinguishable from a factory setup in look and operation ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Window and windscreen are actually both technically correct. However a window screen would be used to describe a screen in front, on or attached to a window. Sorry Procta, no idea about the loom. |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Landreiziger.nl if my memory serves me correctly a defender from 1984 pretending to be a puma with a touch of Range Rover
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
https://rover.ebay.com/rover/0/0/0?mpre=ht...2243212587
And many other option on eBay. |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
my own windscreen electrics were direct to battery, nothing behind the binacle was required. Only thing required was an ignition live feed for the relay which i got from the fuse box. It does use a lot of amps so bear that in mind regarding the earth.
For the difference in price and the inherent problems with Defender misting up it would be silly not to install one, because now that i have one, I think it's probably one of the best mods I did, especially on frosty mornings. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2392 ![]() ![]() ![]() |
How do you switch it then windy or is it on all the time ?
switch is next to the rear wiper switch in front of the middle seat
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
I fitted one to my 200 tdi and I got it from the mobile centre
https://www.mobilecentre.co.uk/land-rover-...tab-screen not cheap.. but perfect length and fit. 1993 200Tdi Defender 90 |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 942 ![]() ![]() ![]() |
Hi, I bought a kit for my TD5 from a place called vehicle glazing specialists, looks factory fit. They did kits for earlier models too.
It's a brilliant upgrade to make as others have said ![]() |
^^^ that kit is sourced from mobile centre I believe Ray
Yep, Dave @ VGS supplies the Mobilecentre kits with his heated screens
Come on Procta... get them bought!
