Home > Technical > 2.2 (2014) intercooler silicone hoses, fitting query |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
1. No need to put the steel protector back. Just make sure the hose is pushed on the intercooler as far as possible. You will then have enough clearance from the bracket the airbox sits on.
2. I don’t think you mean alternator but you can get the clamp back on, it’s a bit of a pain but not impossible. 3. God hates you? |
11th May 2019 10:55pm |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 907 |
Thanks for this. I do mean the alternator though. There's a bracket and clamp assembly that held the old hose to the side of it to stop chafing. I think it was a factory mod from around 2014, but there's no way the clamp will go back without crushing the new hose.
I'm sure God loves me a bit as he kept it dry when I did the elbow hose on the left hand side last weekend, which is the hardest bit of the whole job! |
12th May 2019 7:15am |
I’m very sorry to seriously thought you meant connecting the hose itself to an alternator!
12th May 2019 8:57am |
Ha ha, that was my poor phrasing, sorry about that!
I've just refitted the alternator to hose bracket and had better update this as you definitely DO need to put it back. It doesn't distort the hose very much but it does stop the steering linkage rubbing on it, which of course is why Land Rover fitted it in the first place. It's not too bad to do the bottom nut up on the bracket with a 10mm ratcheting spanner by putting your hand through the largest gap in the fan (there is one gap bigger than the rest if you look hard). It's worth noting that for RHD vehicles, Pete's instructions tell you to remove 15-20 mm from the turbo end of the hose (I used a new blade in a Stanley knife - dead easy), and this is essential as it also contributes to it clearing the steering linkage. |
12th May 2019 10:34am |
