![]() | Home > Maintenance & Modifications > Central Locking. |
All Terrain Member Since: 22 May 2011 Location: Poole, Dorset Posts: 92 ![]() ![]() ![]() |
Any suggestions to this problem. My key fob activates the central locking and the alarm etc. but I can still open the driver's door as if the car were unlocked. All the other doors are locked and the alarm works. Guessing an issue with the actual locking mechanism?
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
got the same but its the rear o/s door, if you find the cause please post it, like wise i shall do the same.
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Probably a broken wire inside the rubber trunking that links the door to the body work.
Common problem. When I bought mine, both rear doors were not locking. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4805 ![]() ![]() |
Yep had a non functioning locking door on mine and it turned out to be a broken wire.Another problem I had was caused by the following. If you do take off the door trim and look at the locking mechanism you will see a little white plastic unit which turns and activates connecting rods. The inside circular piece can be tight and will not swivel. I had to remove mine, remove the centre piece and run a circular file in the surrounding retaining piece. A little oil on reassembly and all was o.k. 1982 88" 2.25 diesel
cheers guys, thats a little job for the weekend then
Gents,
Thanks for the suggestions. My lock on the drivers door is moving but not fully so I assume it is mechanical as opposed to electrical. Are the studs that hold the door card on reusable or will i need to get new ones to refit it once I take it off and fix the problem? Cheers. |
As long as you are careful pulling them off, you can usually reuse them. Craig Rogers
Found out that it is a mechanical issue causing the problem. I assume the mechanism is slightly worn preventing the central locking from locking the door. There is a rod that could be adjusted to lock it but there isn't enough thread on it to take up the slack. Rubbish description of the problem I know!
