![]() | Home > In Car Electronics > Reversing Camera Auto Switch on |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
Hi. Don’t have a Pioneer one but an alpine headunit. But look in the wiring diagram of the headunit. Mine has a separate input wire from the gearbox, to identify wheter reverse is engaged. If i engage reverse the reverse camera is automatically displayed. a defender from 1984 pretending to be a puma with a touch of Range Rover
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21028
As above, and possibly assisted with settings on the HU it’s self ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
| buckers19 Member Since: 02 Jan 2018 Location: London Posts: 95
Thanks for both of your replies. I will investigate this. Instagram.com/mattbuckley19
How did you manage to get a wire from the gearbox switch to the HU? I can’t seem to find any obvious path. Instagram.com/mattbuckley19
Under the gearbox there is a switch. You can trace back the wire from there. a defender from 1984 pretending to be a puma with a touch of Range Rover
| Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 202
Hi could you use the live to the reverse light to feed the camera
I’am a semi professional
| Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123
Yes. You can get video cable with an integral power cable. With tails both ends. I have one in mine so the reverse light triggers the headunit to switch automatically. Only have to run one cable then but does both jobs. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
| Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388
Could I ask what camera you have, and where it’s mounted? 2005 TD5 90 CSW XS
Hi I have a Pioneer ND-BC6 to go with my Pioneer F60 DAB head unit, which has been installed for about a year now, haven't installed the camera yet
I’ve seen reversing cameras up high replacing the back screen washer position then that is moved lower down, seems a good place. 2005 TD5 90 CSW XS
Depending on desired use.
Mine overview when backing up. Camera high up next to the washer. If you want it to couple trailers i would put in the recess of your rear member. Seen a lot of those as well. a defender from 1984 pretending to be a puma with a touch of Range Rover |
