- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Djcla
7th May 2019 8:03pm |
dorsetsmith
Brake fluid spec for TD5
Minimum dry boiling point at 260?C.
Minimum wet boiling point at 165?C.
FMVSS 116 DOT 4 - SAE 1703 - ISO 4925
8th May 2019 7:50am |
rallysteve
Any reputable brand of DOT4 is fine. Doesn't need to be anything special
Cheaper stuff changed periodically will always be better than good stuff that is never changed!
Steve 02' 110 TD5 Double Cab Rebuild Thread
8th May 2019 8:05am |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
