![]() | Home > Td5 > Dead alt / Dead starter - coincidence? |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
Td5 starter solenoid is quite a common failure and super easy to rebuild. $20 kit available almost everywhere. Alternators are also rebuildable but not so easy to get at and remove. Best to replace then rebuild the old one once it is out and keep as a spare.
Good luck. ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
A starter soleniod works or doesn't work. It are the contacts that burn and it suddenly doesn't work anymore.
It is an easy job changing the contact points as said before. If you have the starter motor off take it apart and clean it. Also open the gearbox and get the old grease out and put new in. I used multi purpose grease that might not be the right grease but it works. You don't want to know how much resistance old grease can give. Turn it by hand before and after. You will see. I hardly could turn it by hand and after assembling it again I have a feeling that the td5 turns over faster. Your Altenator brushes are probably worn and were stuck a bit. And came loose so it started working again. Take it off and clean it. take the back cover off and sheck the brushes. There might still be enough life left in them. Having the engine running in sandy water is hard on your altenator. I take my startermotor and alternator off almost once a year to clean them. For your ECU you have a 110 so it is a bit more difficult to find space but I have everything that was under the seat now between my seats at the bulkhead. It takes a lot longer to get wet. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6198 ![]() ![]() ![]() |
Were you in the mud hole that's on the byway just to the east of Westdown camp? (at SU05394759)
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 672 ![]() ![]() ![]() |
Just remove both starter and alternator and clean them from mud. It is not uncommon for alternator to fail after mud bath. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
Ok cool... I have a spare Alt and Starter from a friend who is a breaker coming tomorrow. Once they're off I'll rebuild the originals as my spares
![]() Can't find any earth or trigger wire issues so it must just be that horrible plains silt that it sat in for too long! |
Clean the "new" ones before fitting.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
Clean the old starter when off and leave it in bucket atf. When new one fails swap them. Cheers
All fixed up with the spare parts. Really good condition stuff off of a breaker. Will certainly refurb the old ones as spares shortly. Cheers guys!
- oh yeah, starter super easy... clearly been replaced before... had no top nut so came off with zero hassle. More than can be said for the Disco TD5 I had to pull the replacement off of!!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Really? I have a stack of TD5 alternators (well, at least 3, maybe 4) now that need rebuilding (eg new slip rings, etc) but cannot find spares for them anywhere! Any pointers? |
I used to go to a local alternator shop here and they would rebuild my 300Tdi alternator for $100. They have no idea what the Td5 alternator is like so I searched for rebuild kits. I got the parts off ebay a couple years ago. There were rebuild kits for about £50 sold in the UK. I just looked and cannot find them again. Only brush kits seem to be available. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
