Home > My Defender > Mariner's 200Tdi 90 |
Mariner Member Since: 03 Oct 2017 Location: Arklow Posts: 127 |
Sorry, Procta, I'm not in the market for XS goodies at present.
XS may be a bit too much bling for the retro look |
20th Apr 2019 5:15pm |
Got the cab back on today. I had some sound deadening and insulation lying around so I treated the cab roof as it was prone to drumming from time to time.
Click image to enlarge Click image to enlarge The bonnet went on last week but I need to align it properly as the lock pin is a little off centre. I reckon I can play around with the hinge rubbers to get the small adjustment I need. Click image to enlarge I got a seal kit for the leaking clutch master cylinder but the main seal was slightly different to the original and would not fit so I ended up replacing the entire cylinder. I hope to bleed it this week. Unfortunately I managed to spill a little fluid on the brake servo so that now needs a repaint. The job list is getting a bit shorter and I need to push on now as I have a CVRT (MOT) booked for the 3 weeks time |
5th May 2019 10:10pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Looking good there with the move forward and hopefully no more minor moves backward 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
6th May 2019 8:21pm |
Getting a bit closer to the finish now.
Have the front complete with a new second hand grill panel. The previous one had the key hole for the bonnet lock used on earlier models. I spent a day and a half trying to fit the windscreen with the help of my lady wife. It was almost in a few times but it wouldn't go in the last few inches. I was using a Britpart screen and seal and the seal kept slipping off the glass as if it was a few millimetres too big. I was afraid of doing damage so I called in the professionals and two guys fitted the screen yesterday. It took over an hour and four attempts before it went in. I was happy that my method was right but they had the advantage of two large suction cups, one inside and one outside the glass. They were able to get a good grip on the glass and force it down into the seal and frame. The fitters were very dismissive of the Britpart seal saying it was more like plastic than rubber. The engine started up and ran without any issues so far and tha clutch seems ok but it hasn't left the garage yet. I have a few warning lights on the dash to sort out. I picked up a used headlining and it has greatly improved the cab as I had to live with the bare metal roof before now. I need to fit the wipers, door seals, door check straps and covers and a few bits of trim and then a general tidy up. The headlamps need the beams set and then we should be good for the CVRT (MoT) on Monday week, fingers crossed all goes well. Click image to enlarge Click image to enlarge Click image to enlarge |
18th May 2019 6:53pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4940 |
looking great there!! yeah I know what its like! me and my dad did a glass upgrade on two rover metros, and it took us a good while to get the glass in and out! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
18th May 2019 10:38pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7874 |
Looking awesome, great work! James
19th May 2019 10:14am |
Out in the fresh air today for the first time since Oct '17. I went on a short run and everything seemed ok. The brakes and clutch worked well. I have a few electrical niggles to sort out but the main thing is that it is up and running. |
21st May 2019 1:59pm |
What a beauty, credit to you, great work! James
21st May 2019 3:27pm |
+1 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
27th May 2019 8:32pm |
Thanks guys for all the positive comments and encouragement.
I went public with the project so that I would have to see it through to completion. The forum has been a great source of information and advice with many knowledgeable contributors. In hindsight I think I would have been better off to have repaired the original bulkhead and used a different spray shop for the painting. As the replacement bulkhead was galvanised all the grounds had to be filed larger or retapped and anything attaching to it needed fettling or adjustment and it was a bit of a struggle at times. On the plus side it got me into the garage in the evenings instead of going braindead watching the soaps on tv with the family. I'm thinking of taking the rear tub off next winter to see what lies beneath but for now I'd like to put up a few miles up on her this summer. I went for the CVRT (MoT) on Monday and came on a bureaucratic stumbling block. The renewal date is 17/6 and the test can be done 30 days early and the cert issued. All well and good. However that is only the case if there is a current cert in force. As mine expired in June '18 they would give me a cert until 17/6 and then I would need to test again for a new cert so I decided to leave 'til June and just do the test once. To keep the momentum going I got the MTRs fitted to the Wolfs today. |
28th May 2019 9:12pm |
G4V JW Member Since: 24 Sep 2018 Location: Northants Posts: 190 |
Lovely work, wheels look mega Instagram; @gavin_walding
29th May 2019 10:05pm |
So today was the day for the CVRT (MoT) and I'm a very happy chappy as she passed without any issues
I'll tax her from July 1st and get a few miles up over the rest of the summer all going well. |
20th Jun 2019 9:51pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10361 |
Let's see.
20th Jun 2019 9:53pm |
Hi Greeni,
I haven't put the Wolfs on yet if that's what you would like to see |
20th Jun 2019 9:59pm |
