Home > Maintenance & Modifications > Barrel locks kit
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
Barrel locks kit
Hi
I've tried the search function but can't see anything that answers my query?
Is there a lock kit which incorporates everything so only one key is needed. I've seen one that has an ignition barrel and barrels for the front doors and rear door but is there one that also incorporates the fuel filler lock or a replacement fuel filler cap?
Thanks
Nick
Post #771609 5th May 2019 1:03pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I got this on thurs if this is what you want send the seller your reg to check it fits
https://www.ebay.co.uk/itm/GENUINE-LAND-RO...2795105831
Post #771610 5th May 2019 1:17pm
hank
I wouldn't have thought you'd get a fuel cap keyed alike as the ignition/door key blade is longer than the fuel cap itself > 110 XS Double Cab
Post #771613 5th May 2019 1:24pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
Re: Barrel locks kit
RANGER1312 wrote:
Hi
Thanks
Nick
@ Paddocks you can buy them in sets according to your requirements.
For example on my 90 I only needed 3, driver door, passenger door and rear safari door so that 1 key fits all of them.
Unfortunately the fuel cap key does not get included in the key set as presumably it's a different setup.
Post #771620 5th May 2019 2:47pm
RANGER1312
Thanks for the replies guys!
That makes sense Hank, my locks are a bit miss match for some reason, at least I think they are - it could be LR engineering at its best but my ignition key opens the rear door, my 2 side doors have the same key as the fuel filler cap Rolling Eyes
Post #771623 5th May 2019 3:20pm
RANGER1312
That style key is different to mine Kaney but it looks smart!
Post #771624 5th May 2019 3:21pm
kaney
Thumbs Up
Post #771627 5th May 2019 4:15pm
