![]() | Home > Puma (Tdci) > Summer starting and high oil temperature |
| Bourgui Member Since: 15 Oct 2018 Location: Muscat Posts: 23
Hi All,
now that summer started in the Middle East, we had few days over 40C. Car is driving fine except for a medium loss of power due to upgraded intercooler on its way out. (I am working on the warranty now, should be solved soon). My worry is that both EGT and coolant temps are stable and within the usual range (300C post turbo & 82C with PEL500110) when driving 110 km/h on the flat, but the engine oil temps climbs up to 90C (usually 72/75C in our "winter") then goes down to 78C for no reason and black slowly to 90C and so on. Shall I be worried? Any explanation? Can this be caused by IC leak? Thanks in advance Last edited by Bourgui on 3rd May 2019 4:07am. Edited 1 time in total |
| Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513
90 doesn’t seem high. Mine Goes up to 100. Hot weather, 4 kids, a caravan and up the Mountains. a defender from 1984 pretending to be a puma with a touch of Range Rover
Thanks both for your inputs!
Regarding the thermostat, has anybody drilled it to have it all the time? Temperature over here never gets below 20C so it should not cause any trouble?!? |
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2785
The vehicle is built for it, don’t worry and you’ll enjoy it more.
Jup no problems. Btw it’s the PEL500110 thermostat. a defender from 1984 pretending to be a puma with a touch of Range Rover
