![]() | Home > Series Land Rovers > Series 1 project (Project Womble) |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1256 ![]() ![]() |
Hi
That's a good project. When I did my S1 I had a plan which I have used before which kept me motivated. As I removed an item I refurbished it before moving to the next item I then wrapped and put them aside for later. The main advantage was orderly storage (a land rover in parts takes up several time more space !) and a fast build up. Everything going the other way is clean tidy and you can see it coming together quickly. That said it took over a year to strip clean refurbish all the parts needed before it went back together. Keep sharing photo's as you go..... ![]() 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7939 ![]() ![]() ![]() |
She looks lovely and imagine the end vehicle will be stunning! Good luck and please keep us posted.
![]() ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 455 ![]() ![]() ![]() |
I’ve done some restoration work before, on a previous 86” I had. It turned into a bit of a trailer queen and wasn’t getting used. I think about 500 miles in 5 years which was shocking - so it went to someone who will use it.
The aim of this one is to have something I’m not too precious about, don’t mind taking to work or chucking stuff in the back to take to the tip, and if it picks up the odd dent on the way then so be it. I know it’s possible to spend a fortune on Series one parts and want to avoid that trap if I can. I’ve been lucky so far in that I have either found the bits I need knocking around in the back or in my spares, such as the starter motor I’ve been using to keep a cupboard door shut for about 5 years. I might even call it project Womble!! ![]() Playing bit of catch up with the photos at the moment but the first problem I had (well after having a seized starter motor) was absolutely zero compression on cylinder number 2. Which turned out to be this.... ![]() Click image to enlarge Namely an exhaust valve which was stuck open. A quick tap with a block of wood had it seated again, head back on and the compressions are all even now, even if they are a bit low. I think a bit of use will do it the world of good, assuming that I can get it running, which brings me on to the next part, the ignition - basically there isn’t one. All the loom has been cut out so I’ve made an ignition loom to see if there’s a spark ![]() Click image to enlarge The link wire in the distributor is broken so I’ll need to solder than before I can do anymore. If I can get a spark I’ll be happy so I can get on with bringing the carb back from the dead! |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
A Series 1 makes a nice project I have done several over the years. To be honest while the head was off it might have been worth cleaning up the valves and grinding them in and making sure the exhaust valve seats weren’t cracked, also putting in new oil seals in the inlet valves, non of which costs much money. Good luck with the project though, will follow with interest, as I’m currently recommissioning a 1953 80in.[/i]
Yes you’re right in what you’re saying but I didn’t see the point in going to those lengths if there was still no compression in cylinder 2. The head only takes 20 mins or so to put on.
The plan is that if it runs alright (or at all) I will take the head back off and run through everything with new gaskets, do the valves etc. I’m still not convinced that this will be a runner in its current format. Unfortunately engine parts for these are getting expensive and I was to be sure it’s a useable unit if the money can be spent elsewhere |
Work has got in the way of getting on with much, and this has been further hampered by getting sent some poor parts. This set of points looked like they’d started life in a Kinder egg (the surprise part being the were crap and didn’t work!)
![]() Click image to enlarge The lack of spark however was eventually traced to a dodgy condenser and to cut a long story short....it runs!......even if it’s only for 5 seconds or so at a time. Hopefully once I source a reliable fuel supply for it, and an exhaust system that goes on for more than 6 inches! Now I know it’s a runner I can order a new head gasket set and tidy up the engine before doing a bit on the chassis..... |
While I’m still in the middle of sorting engine bits out, I thought I’d have a look at the chassis. Unfortunately I looked at this bit and could see straight through it!.....
![]() Click image to enlarge And didn’t look much better from underneath.. ![]() Click image to enlarge After cutting a fair bit of the metal away I found the remains of a mouse / rats nest. I think that the nest has held moisture and after being sat for many years has caused the rot. It also looks like whatever has been in there has had a bit of a nibble of the wiring ![]() Click image to enlarge |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1875 ![]() ![]() ![]() |
Never under estimate the damage rodents can do
![]() Looks like you've got yourself a good project there. Watching with interest ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
Have managed to chip away in workshop although my actual job is annoyingly getting in the way...
After the minor success of getting the engine running I’ve had the head back off and put a new head gasket on with a new head to thermostat O-ring and copper pipe. ![]() Click image to enlarge It’s worth mentioning that I had a load of bits from Dingocroft which I’ve never used before and they were really good. They had all the little odds and ends in stock that I needed, and with quick delivery. The carb turned out to be a bit of a pain as there was no mechanism for the accelerator pump on the one that was on the engine so I’ve made one out of two. Quite how this ran properly before is beyond me as the pump mechanism was there but the rod assembly on the main body was missing. I’ve got a complete carb now anyway with all the bits where they should be. I’ve put new plugs in and generally tidied the engine bay up and it’s looking a lot better now, it’s easy to over restore things and that’s not what I’m going for, just tidy and useable. ![]() Click image to enlarge ![]() Click image to enlarge I’ve found an old, slightly tatty exhaust in the rear tub so my job for the day is to see if I can salvage that. I’m trying not to wander too far from the “Womble” ethos Dave |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11067 ![]() ![]() |
Doing a good job there and with the womble ethos
Dingo Croft are very good, can be a tad pricey but customer service and delivery are excellent. Dunsfold and Blanchard also are very good for parts with quick delivery and first class customer service, especially Dunsfold.
Back in work this week unfortunately but did manage to bring the exhaust back from the dead....
![]() Click image to enlarge Turned out alright didn’t it. When I find time this week it’ll be a case of rigging up a fuel pump, and ignition system again to see if it’ll run for any length of time. Back to a bit of welding then as I’ve been putting it off |
Good as the exhaust looked when I tried to fit it I found out it was off a series 2!
Thankfully a friend had a spare one lying around so that was put on. I’m glad I took the time to take the head off and concentrate on getting things right there as with the exhaust fitted it pretty much fired up straight away... |
Sounds sweet
