![]() | Home > Off Topic > another one for the sparkies... |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347 ![]() ![]() ![]() |
Thanks for the info.
like you say 'gravy train'. seems like I might have little choice re the long and refresher course....that said just pulled out my cert from 2012 and it seems to suggest it's a level 3. so perhaps I'll get away with the shorter one (even if it's not the best choice)? ![]() |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3651 ![]() ![]() ![]() |
Give it a go. You have nothing to lose
Out of interest I plugged your 300m of armored into the cable calculation software we use (obviously made a lot of assumptions!!)
16 Amp Type B MCB supplying a 10 Amp single phase load 10mm² 3 Core SWA in a duct buried at 600mm in the ground works. So Brendan, you were spot on ![]() As per my previous email about earthing and RCDs etc. etc. etc. Hope that helps a bit |
