![]() | Home > Maintenance & Modifications > 2015 Service schedule |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Nope not at all
![]() If you also have OCD like me you'll do a much better job that the workshop. If found countless ![]() ![]() p.s. i'am working on an extended service spreadsheet since the LR maintenance doesn't cover all the areas (ie I check injector seals regularly) a defender from 1984 pretending to be a puma with a touch of Range Rover |
Tommo Member Since: 19 Dec 2013 Location: Leicestershire Posts: 830 ![]() ![]() ![]() |
Hi Ant
you will learn a lot about the vehicle, know the job has been done properly and saved ££££. As you are saving you can justify genuine filters etc ![]() |
ant. Member Since: 14 May 2016 Location: staffordshire Posts: 6 ![]() ![]() |
That the kind of thinking I am going for
Cheapest I have paid since buying it from LR is £349 for an A service
A member has very kindly sent me the schedule,
is it the same for a 2.2 as a 2.4 Puma? |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138 ![]() ![]() ![]() |
You can download individual lists at https://osh.landrover.com
Just enter your VIN (the site does no longer need a registration) |
