Home > Maintenance & Modifications > When Genuine JLR Defender parts worth paying for V AM Others
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
Just wondering if there is a list of views already on the site showing when it is worth paying the extra money for Genuine JLR parts against After market copys
My first one being front door seals the after market pair cost around £35 delivered
Genuine JLR pair £122 delivered
The differance being After market one, water getting in, door not closing correctly even being slammed, wind noise, window rattling
Genuine JLR, None of the above Bow down
so what experiance have other owners have in compairing the After market V Genuine JLR.
Maybee we could all save some money by not buying the same thing twice.
Post #769897 24th Apr 2019 5:37pm
dantastic
TD5 fuel pump. Get the genuine part!
Post #769975 25th Apr 2019 9:54am
kaney
Thumbs Up
Post #769977 25th Apr 2019 10:07am
hank
From my own personal experience it's the serviceable/wearing parts...
Genuine JLR steering arm ball joint significantly outlasts cheaper ones
After a few bad experiences with copies I now only use genuine JLR seals/gaskets, particularly rubber ones. > 110 XS Double Cab
Post #769979 25th Apr 2019 10:32am
kaney
Thanks Hank
I have the defender booked in for regreaseing next week and to check again where I have a leak as dripping oil but not needed to be topped up in the engine filler so I will ask the mechanic to use genuine parts as you have suggested
Thanks
Post #769982 25th Apr 2019 11:05am
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Ignition barrel..... such a difference between genuine and aftermarket right through to the quality of the actual key.
Post #770007 25th Apr 2019 1:37pm
kaney
Thanks box of tricks
Another job for me to do as the front door locks don't work so I decided to go for dead locks instead but I do when the money has grown on the tree and is ready for picking have all 3 changed ie rear one as well and the ignition
So much to do on this defender lots of little things which can make it stressful and now and again makes you want to throw in the towel but it's now running superbly and I keep looking at the list I have of what I have done to it and even though I have much more to do I will keep going on with it. what I don't want to do is buy things twice due to being a bad product and if the garage is involved paying twice for labor
Thanks again for your inputs on this topic
Post #770021 25th Apr 2019 2:43pm
