Home > Technical > Rear axle casing ABS to 300tdi
No 6
United Kingdom 1994 Defender 90 300 Tdi CSW Coniston Green
Hi all
Quick question, I'm replacing my rear axle casing, it's got a dent in it and is also leaking around the weld due to corrosion.
I've got a replacement disco casing and it has the bush for the ABS sensor FTC 1384. Can I knock this out and swap over everything else or do I need to buy anything specific?
It's a 94 300tdi disc brake?
Thumbs Up
Post #769670 22nd Apr 2019 10:39pm
DSC-off
Hi, Everything from your 90 defender 300tdi axle should fit straight into a disco 300tdi case. ABS and anti roll bars would be the only additions for the disco, but again they are common to later defenders with those options.
Post #770072 25th Apr 2019 7:43pm
