Home > Puma (Tdci) > Indiscoverable aircon leak
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Aircon isn’t working (again). The system leaks the 600 gr in about a year. Last year it was pressure tested everything ok. But now the system is empty again. I can’t find any obvious leaks.
Anyone have an idea? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769519 21st Apr 2019 9:50pm
Bluest
I thought they could fill the system with a fluorescent dye to help find leaks, has that been done? 2007 110 TDCi Station Wagon XS
Post #769524 21st Apr 2019 10:04pm
Tdi4
Yes. But still can’t find a leak a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769529 21st Apr 2019 10:32pm
dantastic
If there is a leak then the dye will have leaked out too. If you can't see it then it's where you haven't been looking.
Check the condensation runoff over the gearbox to see if there might be come traces of dye there from the heaterbox.
Edit:
I wrote the above assuming you had a puma. I realise that's not the case. But the statement still stands. It's where you haven't been looking.
Post #769537 21st Apr 2019 11:16pm
Tdi4
Thnx. It’s a puma. It’s has the drivetrain and the dash (and therefore the aircon) of the puma.
I’ll look above the gearbox Thumbs Up a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769549 22nd Apr 2019 7:19am
Tdi4
Just a quick question. You should be able to see the dye without a uv lamp? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #769552 22nd Apr 2019 7:45am
Bluest
A very quick Google video search suggests that the dye may be UV, so you might need a lamp. 2007 110 TDCi Station Wagon XS
Post #769553 22nd Apr 2019 7:56am
