Home > Td5 > EGR valve Delete kit
Procta
Ok lads where is the best place to get the a decent kit? I have seen on ebay a few things, but not sure what why and when.
The 300 had a pipe and a few odds and sods, this looks like its got a pipe and a blanking plate separate? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #768485 13th Apr 2019 11:36pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Yes it has a pipe and a blanking plate. Very different from the 300Tdi. The pipe replaces the EGR valve and the plate covers the hole where the gasses come into it on the exhaust side of the motor. Suggest you look for a stainless unit rather than a mild steal. Most seem to be decent quality hence the broad recommendation rather than a specific supplier.
Good luck. Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #768492 14th Apr 2019 2:28am
landy andy
I hunted around and found X8R kit that I liked the look of. All really really nicely made, all the bolts and gaskets. Good fast delivery
https://rover.ebay.com/rover/0/0/0?mpre=ht...2139701603
Post #768505 14th Apr 2019 8:16am
landy andy
The one above that I bought is for the later egr that has a cooler on the front of the engine, so extra blanks are required. Earlier ones don’t have the cooler so their cheaper kit can be used.
Post #768507 14th Apr 2019 8:18am
Here you go - it's a well hidden advert but is what you're looking for:
https://www.defender2.net/forum/topic66833.html Darren
Post #768513 14th Apr 2019 9:17am
Lionel
Australia
I have just fitted one of these excellent kits to my 2004 TD5 Defender. Can thoroughly recommend them. Mine was the more expensive kit for the EU3 15P TD5 with cooled exhaust EGR inlet, which needs to have the extra blanking plates.
Cheers,
Lionel
Post #768785 16th Apr 2019 8:13am
You don't need any extra bits for a vehicle with the EGR cooler, just the pipe to replace the EGR valve and the blanking plate for the exhaust manifold port. The EGR cooler can be left with the coolant pipes connected and the the inlet and outlet exhaust gas ports open.
A neater result can be obtained by removing the EGR cooler completely and rerouting the inlet coolant pipe to the destination of the outlet coolant pipe (or I suppose just connecting the inlet and outlet pipes together with a suitable coupling). I can't be more specific about the coolant pipes on a Defender since I have only done this on a Disco which, I suspect, is different.
Post #768790 16th Apr 2019 9:06am
landy andy
It’s easier to just leave cooler in place just incase you need to reinstate the egr, as mot laws are changing. It’s only going to be extra cooling. I prefer to blank the ports on the cooler as I don’t want any rubbish getting in there, and it’s only a couple of quid extra.
Post #768805 16th Apr 2019 10:24am
GoatRider
United Kingdom 2002 Defender 90 Td5 HT Bonatti Grey
TD5 2002 Which Kit?
Looking at this eBay supplier the kits look ok but I'm not sure which to go for. Any advice welcome.
I'm thinking that the one with a take off for a Boost Guage might be the way to go. I am about to upgrade the intercooler and do a stage 2 but not thinking about changing the turbo, nevertheless is a boost guage worth having? Doesn't that connect directly to the turbo?
Sorry, a bit confused on this one.
Cheers,
Nick
 Man who run in front of car get tired. Man who run behind car get exhausted.
Post #850392 16th Aug 2020 8:25pm
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
Hi
I went with one of these:
https://x8r.co.uk/instructions/index.php/2...rint=print
Once I got the EGR off it was very easy to fit.
Well worth doing. Wouldn’t know what to with a boost gauge. Just another dial to worry about.
Post #850394 16th Aug 2020 8:28pm
