Home > Maintenance & Modifications > eBay diesel heaters
DOOFER
eBay diesel heaters
I’ve had a mooch round eBay and this site but can’t find the answer. I’ve been looking at the MUD heater box to fit in the centre of my 90. It says it takes 2kw heaters such as webasto , eberspacher and most Chinese copies. It gives a height of 140mm externally. But all the eBay heaters I’ve seen show a height of 140mm - 160mm from the base plate. Has anyone on here actually fitted one or just own one that could take a measurement for me. This is just for the 2kw versions
Cheers DON'T PANIC
Post #767839 9th Apr 2019 2:40pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Ill measure tonight for you 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #767844 9th Apr 2019 3:04pm
DOOFER
You’re a gent DON'T PANIC
Post #767845 9th Apr 2019 3:12pm
leeds
ebay diesel heater
With ebay diesel heaters be careful, some claim to be Planar, Webasto etc but they are nit. They are also not approved as vehicle heaters.
The Nakatanenga heater box for Planar/Webasto heaters is 160mm external height and is designed to fit where the cubby box in a Defender normally sits. Complete Defender kits including Planars available here
Brendan
Post #767868 9th Apr 2019 4:56pm
pj2106
Fitted on flat boot floor 150mm floor to top 2008 110 2.4 XS Utility (Hagrid)
Post #767869 9th Apr 2019 5:10pm
DOOFER
Thanks for that. Bit of a pain though. Too big for the mud heater locker. DON'T PANIC
Post #767877 9th Apr 2019 5:47pm
pj2106
Build your own 2008 110 2.4 XS Utility (Hagrid)
Post #767878 9th Apr 2019 5:56pm
DOOFER
I probably could. But I have the raptor engineering cubby and the arm rest would be far too high. I’ll have a rethink about installation. Out of interest, how are you getting on with your heater and where did you fit it? DON'T PANIC
Post #767881 9th Apr 2019 6:06pm
pj2106
Fitted in back of my 110 after removing 3rdrow seats
Not got it connected atm as not that cold and re jigging the rear
Over winter I used it a lot on the timer 30 minutes on before I went to work and it was warm inside and fully defrosted
Brought a 5 litre diesel tank rather than the 10 which fit in the landy much better
Will be moving it to undersecond rowseats when I do my conversion
Easy to fit and pretty good on fuel used about 1.5 litres in7 days when on defrosting and that included 30 mins before I went home from work to
Definately a great addition I gotmine of eBay £138 with digital/manual/remote controllers only used the digital and remote which onceyou get the hang of programming it pretty easy 2008 110 2.4 XS Utility (Hagrid)
Post #767927 9th Apr 2019 9:54pm
Gilloverland
Just fitted one to my 110 (https://www.defender2.net/forum/topic66584.html).
It works great. The Chinese ones off ebay, amazon, aliexpress etc come in 2 sizes - 2kw or 5kw. The 2kw are pretty much like for like with eberspaher / webasto. The 5kw ones are bigger.
There is a facebook group for them, with pages and pages of technical know how, how to change the fueling settings, which parts interchange and all sorts.
For the price they are really good and shows just how much you're getting ripped off with a webasto or eberspacher (in fact both were fined for price fixing)!
Post #767955 10th Apr 2019 7:59am
Mo Murphy
Wow, so they did !
''Parking heaters (COMP 40055 – 17 June 2015)
– The Commission fined producers of parking heaters –€68 million (settlement)
– Two German companies involved Eberspächer and Webasto
– No fine imposed on Webasto – leniency applicant
– Allegation of coordination of prices and allocation of
customers with regard to fuel-operated parking heaters and auxiliary heaters
– 10 years of collusion (2001 to 2011)''
Source: Mayer.Brown
50 Shades of Pennine Grey
Post #767961 10th Apr 2019 8:31am
dantastic
Have they stopped the price fixing??
I have an Eberspacher myself but the price of parts is just not worth it. You can buy 2 new Chinese complete heater kits for just a new Eberspacher blower assembly. You can buy 3-4 new Chinese ones for the price of a new Eberspacher ECU.
If you treat the Chinese units as disposable then you are really not out of pocket. They are fine.
I have for the record had the unpleasant experience of having to deal with a Planar as well and I rate it much lower than any of the Chinese units I've seen. The Planar works as such but the controls are right hateful. Much prefer the Chinese units.
Post #768029 10th Apr 2019 3:55pm
