Home > Puma (Tdci) > Oil?
Merlin
Oil?
I've managed to put 5W/40 oil in instead of 5W/30. Should I change it or do you think it doesn't matter as the next oil change is in 6K.
Merlin
Post #76779 20th Jun 2011 9:55am
ibexman
It should be fine
Post #76780 20th Jun 2011 9:58am
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Won't really matter as long as the spec of the oil is correct i.e ACEA ratings
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #76781 20th Jun 2011 9:59am
MK
It is too thick. And. I don`t think it is A1/B1 or A5/B5. Most x-W40 are A3-B3-B4-E7 etc Puma 110" SW
Post #76787 20th Jun 2011 10:52am
stevie d
A3/B4 oil won't cause a problem, it is a higher spec oil than A1/B1, but it is not a fuel saving oil. (A1/B1 is now a relatively old spec and many mineral based oils can achieve it, A5/B5 being the updated version).
A3/B4 has a higher High tensile stress rating required by some engines, but that doesn't come with fuel saving, otherwise the oil is the same as A5/B5.
There are not many x/w/30 oils that achieve A3/B4 normally x/w/40 or above.
Discovery 3 HSE
BMW 330i Coupe
Post #76853 20th Jun 2011 6:07pm
MK
ACEA specs do not address the viscosity issue directly. Viscosity and HTHS value is not a direct relationship. Puma 110" SW
Post #76859 20th Jun 2011 6:46pm
Merlin
Hey, this is all a bit technical for me. I’ve read the label and it says: API SM/CF ACEA A3, B3, B4. Is this ok?
Merlin
Post #76997 21st Jun 2011 4:10pm
MK
It is not great but it should be ok. Personally I would switch back to the OE specs next time. The engine was (including oil pump) was designed to run a 5W-30 and a very specific one. Have a look to the Opie oils website. Thumbs Up Puma 110" SW
Post #76999 21st Jun 2011 4:18pm
stevie d
It will be fine, hotter country's use thicker oil anyway.
Discovery 3 HSE
BMW 330i Coupe
Post #77048 21st Jun 2011 8:38pm
dgardel
Italy
That means less wear ............. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #77052 21st Jun 2011 8:42pm
MK
Steve Thumbs Up
Interesting. What oil LR recommends for such hot countries? Puma 110" SW
Post #77070 21st Jun 2011 10:02pm
Naks
IIRC for Dubai it's an Xw50 or Xw60 oil --
Post #77091 22nd Jun 2011 6:18am
astoltz
South Africa
I service my car in between the dealer service.
Beginning 2011 I found out Midrand and Centurion Dealers in SA uses Castrol SLX Professional 5W30
I used the same on my "in between service" but would have like to use Shell Helix Ultra 5W40 or Even Mobil 1 0W40) (I think 5W30 is to thin for our summer climate and going north over our borders)
So this week Land Rover Centurion serviced the Puma and they used Mobil 1 0W40 (And this was not at my request Smile
Now me too will switch from 5W30 to 0W40 or 5W40
Edited since last posting for Clarity: (it is Mobil 1 -- (0W40) I am refering to above)
Regards
Abrie
PS: See ful post at:
http://www.4x4community.co.za/forum/showpo...stcount=13 1997 Land Rover Defender 110 HT 2.8i
(BMW M52)
2009 Land Rover Defender 110 HT 2.4 TDCi(Puma)
Post #78523 30th Jun 2011 8:45pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Steve Thumbs Up
Is Newmarket in a hotter country then Shocked
Post #78524 30th Jun 2011 8:52pm
4wheeler
Australia 2013 Defender 110 Puma 2.2 SW Chawton White
My dealer has supplied Castrol Magnatec 5w/40 from new. The Defender now has 42,000km on the odo. Car seems to run fine on it and does not consume much of it between services (10,000km interval) and best of all, it seems to stay in the engine and not end up on the ground!
Fuel consumption running this oil is around 10 litres per 100 km - doesn't seem to change much.
Post #78555 1st Jul 2011 5:46am
