Home > Series Land Rovers > Aluminium. Vapor blasting or hand finish
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Anyone know what JLR Classic is using to restore their aluminium parts? I get good results with brushing but still wondering if I should get them vapor (not soda) blasted to keep them 'clean for longer.m
Post #767328 7th Apr 2019 6:20am
discomog
If you want the best possible finish then vapour blasting is the way to go. Gives aluminium casting that brand new finish. Santorini 90XS SW
Discovery Sport
Morgan Plus 8
Post #767343 7th Apr 2019 8:29am
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I would agree that vapour blasting is excellent for cast aluminium parts, I have used it a lot on my Series vehicles engine parts. 2015 Defender 90 SW / 1985 factory V8 Ninety
1953 80in ex Australia
1955 Series 1 now owned by my son
Post #767380 7th Apr 2019 11:11am
100inch
Thanks for the heads up. Does it stay close to cast finish? I want to replicate the original look as much as possible. m
Post #767540 8th Apr 2019 7:51am
discomog
Vapour blasting is not as aggressive as grit, sand or bead blasting, due in the main down to the use of water as a lubricant. If you know a local company that carries out vapour blasting why not ask them to show you some examples of their finished work. Santorini 90XS SW
Discovery Sport
Morgan Plus 8
Post #767543 8th Apr 2019 8:13am
100inch
Thanks for all your answers. Convinced. Will post some pictures once done. m
Post #767567 8th Apr 2019 10:17am
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
