![]() | Home > Maintenance & Modifications > Using 2 standard batteries for dual battery set up |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8322 ![]() ![]() ![]() |
+'ve to front batt. Std earth to rear batt. Then flying leads connect two earth and connect two +'ve to run two perm linked in parallel.
Or +'ve through split charge/vsr to have as separate charging. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4289 ![]() ![]() ![]() |
That’s how I was thinking of arranging them, but the +ve cable won’t reach quite far enough to get on the +ve terminal of the start battery. 2007 110 TDCi Station Wagon XS
No problem
+ve at the front middle of vehicle and it doesn't reach? It's only moved a few inches and moved closer to cable inlet routing has itnot? Post a pic Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Think maybe I’ve got the battery the wrong way round. I’ve got the +ve terminal nearest the door. 2007 110 TDCi Station Wagon XS
