Home > Td5 > Snorkel
Gozy
United Kingdom 2004 Defender 90 Td5 SW Aintree Green
Snorkel
Thinking of a snorkel for my 2004 Td5 defender. Which make do you all recommend please. Also to waterproof the air intake it does not stop there , I think there’s other areas that need waterproofing many thanks for your advice.
Post #767138 6th Apr 2019 4:08am
landy andy
The Land Rover one looks best, but the Safari is better to make fully waterproof. Although you can make the LR one waterproof. There is all the pipe connections a water drain valve in pipe from air intake to air filter housing and drain hole in air filter housing. All need to be sealed to be fully waterproof.
Post #767142 6th Apr 2019 7:06am
grafty99
There are so many joints in the standard air intake you'd probably be best off replacing the wing to airbox pipework for a single piece of pipe IMO Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #767146 6th Apr 2019 8:02am
Alitaff
Hi Gozy, I was going to fit one to my 2003 td5 before I sold it but came across some concerns regarding the air restriction it could cause at certain speeds.
I could be wrong but it is worth looking into it before fitting one, good luck 👍
Post #767151 6th Apr 2019 8:51am
roel
You also could make your own.
With this one I can push a tree to the side and just loose some paint. Twisted Evil Roel
2003 90 Td5 (2009-now)
Post #767158 6th Apr 2019 10:18am
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have a southdown raised air intake -
stainless pipe, but powder coated black
new pipework through to filter box - no leaks for water ingress
my engine is quite highly tuned and have no issues with air flow - the faster you go the more air is forced down the pipe
Only issues is going through leafy vegetation that can block the intake - but you are only going slowly so not an issue to remove
Post #767161 6th Apr 2019 10:25am
ibexman
See if you can get hold of a safari V8 this is sealed and has continuous flexi hose Thumbs Up
Post #767169 6th Apr 2019 11:05am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Land Rover RAI is very sturdy and I have sealed it up. Not very easy to fit just any aftermarket to a LHD Td5 intake. Good luck Thumbs Up
 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #767196 6th Apr 2019 3:27pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
Don’t forget the fuses and relays below the drivers seat on a td5. They need to be sorted if you want to go wading deep. 2002 td5 90 county hardtop
Post #767210 6th Apr 2019 5:03pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Unless you really need one, don't fit one!
Post #767220 6th Apr 2019 5:40pm
Procta
the defender I was going to go after had a snorkel on, and I was going to ask the dealer to remove it, my dad winged on at me about it, But like Mike says if you really need one then go a head, I don't think they are practical for road use motors, yeah great if you are going off road, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #767222 6th Apr 2019 5:46pm
landy andy
Why anti them?
Cleaner air up high. I don’t like the idea of all the water spray when motorway driving in rain without one. No loss in performance with one fitted. And I’ve had no relay issues when wading. Just practice good technique, get a bow wave, and avoid stopping in water.
Post #767236 6th Apr 2019 7:02pm
landy andy
Duplicate post
Post #767238 6th Apr 2019 7:03pm
Procta
landy andy wrote:
Why anti them?
I personally don't like the look of them, but I can see some performance gains with the cleaner air Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #767250 6th Apr 2019 7:24pm
landy andy
I like them and have fitted them to nearly all my LRs, but each to their own. I hate the idea of playing, then someone else ploughs through the water you are in, and wave enters the air intake. For me I dislike all the big wheel shiney, never see mud ones.
Post #767254 6th Apr 2019 7:28pm
