![]() | Home > Puma (Tdci) > Ignition Wiring - Help |
https://www.defender2.net/forum/post561588.html
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 751 ![]() ![]() ![]() |
The red immobiliser light has come one the dash so now wondering as I disconnected the battery how do I resync the immobiliser?
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
Triple check the connections:
![]() Turn the heater fan on (position 3). Turn the key, does the fan come on? ![]() ![]() |
When you say the ignition doesn't come on, do you mean there's no power to the dash etc?
Thanks guys. Fixed. Silly mistake on my part
God I love this forum. |
Do tell
When I took the old barrel out it only had three connectors so replicated when replacing. Only to find the forth disconnected itself as connector really loose!
Before you reassemble everything check the terminals are tight enough on the switch tabs so that they won't fall off in future.
Gently pull each wire to see if you can pull the terminal off the switch. You shouldn't be able to without sliding the plastic coloured terminal cover away from the switch first. ![]() ![]() |
Yep done that. It’s where two wires both go into one connector that then slides onto barrel. Unfortunately previous owner was crap at electrics and it’s a big mess with lots of old wires randomly cut behind the dash
The original harness isn't like that (there's only one wire per terminal) so sounds like there's been some mods there.
It’s like everything in life. You spend more time cleaning up other people’s mistakes than it takes to actually get the job done.
Thanks really appreciated your help today. Have a good weekend. Jeremy |
