Home > Puma (Tdci) > Higher engine oil and fuel consumption? |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 86 |
Blimbug, What is the Km that you have and how much is the consumption?
14th Mar 2019 11:24am |
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 |
It's done 67k miles, was serviced approx 7k miles ago and the oil had dropped about 1 cm on the dip stick (don't know what that equates to in litres - sorry!)
14th Mar 2019 12:15pm |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 |
Check out the injector copper washer/seals. Lots of threads on this as it is a very common issue. I had mine done 2 years ago as it started burning a bit of oil. Since they were changed its gone back to burning nothing between services.
18th Mar 2019 9:59am |
Thanks for the recommendations all.
Off to do some research! |
18th Mar 2019 9:47pm |
daxdocx Member Since: 02 Nov 2013 Location: Ingolstadt Posts: 8 |
got same problem as rossy, we changed the copper sealings at the bottom of the injectors and it was gone ... be aware the srews are fixed with 6NM at step one and 180 degrees in the 2nd step
29th Mar 2019 11:26pm |
Blimbug, could you solve the problem of oil consumption?
Regards |
23rd Aug 2019 10:39am |
