Home > Puma (Tdci) > OK to reuse engine oil? |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 296 |
Not a good idea..
28th Mar 2019 3:18pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Just no... modern common rail diesels do not like anything other than diesel. Even some other less refined diesels in foreign regions can play havoc with injectors and the injector pump. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
28th Mar 2019 3:38pm |
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 |
Glad I checked!
Best way to get rid of used engine oil? Trip down to the local tip? Thanks! |
28th Mar 2019 3:49pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
I used to do this on my old Disco. After changing oil on Disco, Volvo, Motorbike, Lawn Mowers, I had a LOT spare/used oil every spring. Bought a filter off ebay, and used it in the Discovery (about 1 litre to every full tank). NEVER had a problem, and I bought the vehicle new, and owned it for 187,000 miles. Mechanically it was still A1 when I sold it.
Not sure I would do it in a later vehicle with CAT, DPF etc... Now I take the old oil to the council tip for re-cycling. In fact I have at least 20 litres now (just changed the oil on the GF's Astra... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
28th Mar 2019 3:57pm |
Your local tip should take it. Best to check online before you go though 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
28th Mar 2019 3:59pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2496 |
You could send it to our local chippy, they are in desperate need of an oil change. Not a good idea to put it in your Defender, don't we have enough problems with them already. Defender 90XS SW
28th Mar 2019 5:26pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
great for painting your fence DEFENDER 90 TDCI XS,
28th Mar 2019 6:46pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
Illegal for painting your fence.
28th Mar 2019 7:40pm |
/www.surreycc.gov.uk/waste-and-recycling/community-recycling-centres/woking |
28th Mar 2019 8:25pm |
lonewolf Member Since: 23 Oct 2013 Location: North East England Posts: 206 |
Some folk slap it onto their chassis for protection, but if you can’t put it onto your fence like Blackwolf suggests perhaps
that is illegal too.......maybe someone can advise? |
28th Mar 2019 10:55pm |
RoddyK05 Member Since: 08 Apr 2015 Location: Inverclyde Posts: 633 |
Most things are illegal these days, and getting worse
29th Mar 2019 1:17am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19608 |
Well it is carcinogenic and environmentally damaging so it isn’t surprising. It then also has the capabilities of contaminating land, and watercourses. Then to the water table and ultimately drinking water and habitat for wildlife. Anti freeze isn’t too dissimilar either and rightly should be disposed of correctly. However, local authorities deliberately make things as difficult and as expensive as they can!
I expect garages would take it too for an environmental fee. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
29th Mar 2019 1:24am |
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 242 |
If you put it into a clear container you may find that the fuel and oil separate. then you can siphon off what you want.
I know petrol and diesel mix separates, so maybe the diesel/oil mix will also. I got hold of 50l from a miss fuelled car many years ago, after leaving it in a clear container for a few days I could suck out and use the petrol. 1953 80" 1987 mini city e 2011 90" |
29th Mar 2019 10:34pm |
Whitcliffian Member Since: 15 Nov 2017 Location: Yorkshire Posts: 33 |
I have just caught up on this thread & it caused me to remember something from my time in Africa. In the early ‘eighties I worked in Angola. It was on some mines there & the company involved extensively used Series L/R’s, Fuscas, (Brasileiro VW Beetles) & CAT earthmoving equipment as well as lots of other machines & vehicles.
Conditions were challenging. Parts were reused on a very regular basis to the extent that the scrap yards were well visited. My anecdote is that the mechanics said they did sometimes reuse engine oil when doing a first service. I think they thought it was of a better quality with it originating from UK when compared to the locally sourced engine oil. The locally sourced engine oil was readily available in the workshops so presumably it was a question of preference. I can only remember the mechanics doing it at a first service. I am not suggesting that anyone does the same today. |
8th Apr 2019 4:35pm |
