Home > Td5 > Flywheel to replace or not to replace?
kweese
Canada 1999 Defender 110 Td5 SW Belize Green
Hello, I'm having my clutch redone because I seems like the bearing is faulty. Would you guys recommend redoing the flywheel? I'm asking because the part is not cheap and also, when the car is on the hoist if i dont have the flywheel it will take a few days to a week to get.
Post #764909 22nd Mar 2019 10:09pm
lightning
The people replacing the clutch should be able to tell you if the flywheel needs changing. If it’s worn, change it. If not, don’t bother.
Post #764913 22nd Mar 2019 10:47pm
I have found that the clutch generally lasts longer than the flywheel on a TD5, and I can't really imagine circumstances where I'd change the clutch and not the flywheel.
Post #764922 22nd Mar 2019 11:40pm
When mine was done they said the flywheel was in good condition so it was left in situ.
I would tend to go by that, of course change all of it though if you feel a need to and a budget isn’t an issue.
Although, I’d stick to ‘if it isn’t broke, don’t fix it’. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #764926 23rd Mar 2019 12:01am
JWL
Last year I did an engine swop on my 200K 15P Td5 Defender and the newer secondhand engine came with a new clutch/flywheel/cover plate that was less than 12 months old, a bit of a bonus I thought. Less than a mile up the road on the way home from doing the engine swop we lost all drive.
Took the gearbox out the next day to find that the centre had cracked out of the friction plate so I took the one off the old engine, compared the two and there was very little difference in the "meat" on the friction material so popped that in and it's been fine for the past 15K miles. The flywheel was totally shot plus grooved and the cover plate was grooved and the spring fingers were allmost worn through but then again the date mark on that one said March 2004 so looking up the service history the motor had done around 40K miles by then so over 160K miles it was about time it had a change.
Post #764927 23rd Mar 2019 12:56am
Yours is a.Puma though, not a TD5 with a dual mass flywheel.
Post #764986 23rd Mar 2019 2:38pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Personally, given the time required and effort to pull a gerabox and do the work, I consider it false economy not to change both in a Td5. Food for thought.
Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #764993 23rd Mar 2019 3:59pm
Procta
can you get single clutch and flywheels for these? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #765020 23rd Mar 2019 6:41pm
If you mean can you get a solid flywheel and sprung clutch, yes you can. Some swear by them, some swear at them
Post #765079 23rd Mar 2019 10:12pm
jst
If on a td5 and I was doing the clutch I would do the flywheel to without question. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #765089 23rd Mar 2019 11:11pm
4RF RDS
Yes, there are a few custom fabricators in the UK that I am aware of. I have no personal experience with any for the Td5 however I have heard they are best for extreme off road and high performance rather than daily use. Do a search here for this if you are interested. Personally, again, were it me I’d stick with the DMF and Valeo clutch. I think a company called clutch fix has a good reputation?? Perhaps others might chime in with their experience.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #765095 24th Mar 2019 1:56am
