Home > Maintenance & Modifications > Fitting Bowler Steering guard
Brendlynch
Jersey 2005 Defender 110 Td5 XS CSW Cairns Blue
Hi
Apologies if this is a stupid question, complete novice here.
Has anyone fitted a Bowler Steering guard to a TD5? I was under the impression that it would be a fairly simple ‘bolt on’ job (admittedly I’m not the handiest at this kind of stuff) but appears to be a little more complicated and I’m not sure whether the guard is compatible.
The mounting bracket circled in the attached picture is bolted to the chassis where the rear left steering guard bracket bolt needs to go. Logic says that this needs to be unbolted and the guard bracket should sit between the mounting bracket and the chassis but I can’t see how this would work when bolted back together presumably it wouldn’t line up correctly due to the thickness of the steering guard bracket.
Thought it was a job I could do but maybe for someone who knows what they are doing. Any tips appreciated.
Post #764839 22nd Mar 2019 3:53pm
JOW240725
Not sure if this helps https://www.defender2.net/forum/post539710.html
Possibly a better video https://www.google.com/search?client=firef...#kpvalbx=1
Neither specifically Bowler but might help? James
Instagram @suffolk_rovers
Post #764843 22nd Mar 2019 4:36pm
Brendlynch
Now I feel stupid. Inside of the chassis.
Thank you!
Post #764845 22nd Mar 2019 4:51pm
JOW240725
I would be exactly the same, it's what makes these forums, google and youtube invaluable to us novices Thumbs Up James
Post #764850 22nd Mar 2019 5:09pm
Brendlynch
True! I’m in absolute awe of some of the projects undertaken on here. Bow down
Post #764854 22nd Mar 2019 5:21pm
dorsetsmith
Steering Drop Arm Ball Joint before fitting steering guard Idea
Post #764856 22nd Mar 2019 5:44pm
Roy5695
Id also be changing that drop arm ball joint. the rubber boot doesn't look intact any more! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #764881 22nd Mar 2019 8:33pm
