Home > Maintenance & Modifications > Aluminium corrosion treatment - something i saw on here....
donmacn
Hi,
I've searched and searched until my fingers and eyes are sore!
I know the question of treating allu body panels has been covered before, but I am certain (as certain as I can be) that I came across a post on here a little while ago showing a "bottle of stuff" that could be used on aluminum panels. Kind of like the equivalent of Kurust, but for aluminium.
Same as everyone else no doubt, I have lots of places where the paint has bubbled or 'spidered' and I want to treat this before getting the car sprayed. I'm going to brush it down (using scotchbrite, or brass, not steel) and then etch prime it, but if it made sense, I would use this mystery "bottle of stuff" prior to etch priming.
(This is on body panels where there is no steel behind. I'm quite up on galvanic corrosion, and am slowly going round the car isolating as many steel/ally bonds as practical without taking the body off or completely apart...again.)
I may be going mad, and this might be a wild goose chase, but I thought I'd ask. There's a reasonable price tag on re-spraying a 110, so I'd like to make sure I get it as right as possible. The agreement is that I do some of the basic prep before taking it to the paint-shop to save some pennies.
I'm not actually that bothered about a gleaming factory finish I could use as a mirror. In fact if it wasn't for the fact that shiny new doors are going on, I wouldn't be getting it painted at all. Quite happy with scratched and faded red, but that's OK if all the panels are scratched and faded. Once new doors go on, it would look daft I think. Hence the paintshop.
Blah blah blah. Confused
If anyone can point me in the direction of the post I'm looking for, or for the 'aluminium magic potion' I'd be grateful.
If you zoom in on the rear quarters here, this is the sort of stuff I'm talking about.
Ta. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #764114 18th Mar 2019 11:10am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
Post #764123 18th Mar 2019 12:41pm
donmacn
Thanks mate,
It could be the right stuff, though I think it was a 'treatment' rather than a cleaner. I think that's why it stuck in my mind - but I should have hit 'follow topic' at the time.
The picture I saw was a translucent/opaque bottle, with a plain white screw top....
Like I say, maybe a wild goose chase, but thanks for the reply. Donald
in the past..
Post #764127 18th Mar 2019 1:35pm
gilarion
In the past, I have used Isopol metal filler, make sure its metal filler and not the plastic variety. Sand of as much of the corrosion as possible and then fill sand and paint. While I do not still have the Defender I repaired I did own it for more than five years after I did the repair and it still looked fine. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #764128 18th Mar 2019 1:41pm
Oakseywick
Is this the tread I took a screen shot when I saw it too as I thought it may be helpful dealing with panel corrosion prior to repainting work.
Post #764129 18th Mar 2019 1:44pm
Alitaff
That is good stuff but wear gloves when using it, good luck πŸ‘
Post #764153 18th Mar 2019 3:20pm
Martin
Site Admin
https://www.defender2.net/forum/topic66190...t=aliclean  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #764170 18th Mar 2019 4:59pm
That aluminium stuff is dangerous stuff, be very careful handling as suggested.
I've seen a lot of comments on YouTube about such products that are very caustic indeed! ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #764174 18th Mar 2019 6:39pm
donmacn
Perfect, gents! That's exactly the thread and info that I was looking for. Now that I have that, I'll have a good look at the product and see if it makes sense for me.
If I use it I'll report back.
Thanks again. Donald
in the past..
Post #764201 18th Mar 2019 8:57pm
Bigluckily
United Kingdom 1998 Defender 110 300 Tdi SW Epsom Green
Hi donmacn, did you find a good supplier for "Ali Clean"?
Post #765592 27th Mar 2019 7:27am
donmacn
Kind of a 'yes and no' reply to that.
I was speaking to the technical guys at Frosts restoration about their POR15 paint and its use on aluminium.
He advised using their 'metal prep' stuff first; putting it on for 20 minutes; then rinsing off, at which point it was leaving behind a zinc sulphate covering for priming (maybe?? I don't have my notes to hand, but it was something like that).
So I've gone for that and it's in the post, so I'll see how that goes. It might well be the same sort of stuff.
I'll post back on here when I get it and use it. Donald
in the past..
Post #765605 27th Mar 2019 9:24am
Bigluckily
Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #765684 27th Mar 2019 5:33pm
