Home > Puma (Tdci) > Electric window malfunctioning |
My passenger side electric window does not work. Driver side works normal. Any ideas where to start looking?
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
16th Mar 2019 9:23pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 3997 |
Fuse first, then look at the wiring loom where it goes from A post into the door. 2007 110 TDCi Station Wagon XS
16th Mar 2019 9:30pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5424 |
The two thick wire from A post to door.
16th Mar 2019 9:40pm |
Thanks, will check tomorrow.
16th Mar 2019 9:57pm |
check wiring in swan neck between door and the A pillar be good place to start
16th Mar 2019 9:59pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
My passenger window stopped working and I was amazed to find (after testing everything with a multimeter) that the motor was full of water!
It must have been rain water because I've never dunked my defender that deep! Anyway tipped the water out, dried it, sprayed with WD40 then gave it a light smear of copper slip. It's been fine ever since So start with the fuses and wiring, and if that's all OK then look at the motor 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
17th Mar 2019 10:49am |
