![]() | Home > Puma (Tdci) > Brakes Squealing! |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Chances are, the squeel is actually the back of the pad and not the friction surface.
It vibrates inside the caliper and squeels against the piston. Some pads come with a sticky rubber pad to stop it, if not, you can put a small amount of copper grease on the back of the pad...... Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
Yup, mine scream like a banshee most of the time, it is loud enough to make people look round. I have tried all the conventional rememdies, and the sqeal always come back eventually.
They also rattle when not appplied as you drive along, and this too seems impossible to cure. |
Tim_NZ Member Since: 05 May 2008 Location: Australia Posts: 177 ![]() ![]() |
Only solution I found was a new set of pads
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
Get occasional squealing but it's very quiet. Doesn't bother me. Defender 110XS SW gone... now VW California 180 4 Motion.
haworthj Member Since: 01 Nov 2010 Location: Sussex Posts: 178 ![]() ![]() |
My offside front squeals occasionally. It's not bad, so it doesn't bother me, and also it's intermittent.
Jimbob Member Since: 17 Mar 2011 Location: Gower Posts: 68 ![]() ![]() ![]() |
Yup, back passengers side always squeals and always has done since Ive had it. One of those things I think! 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader 2015 Defender XS Hard Top (awaiting delivery 😄) |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 ![]() ![]() ![]() |
Looks like I'll try the cooper slip and if not put up with it. Dosn't really jar me off much just noticeable.
Thanks guys ![]() |
