Home > Td5 > Downpipe Removal
Emptywallet
United Kingdom 2005 Defender 110 Td5 CSW Tonga Green
Downpipe Removal
Ladies and Gents
Is there a clever trick to remove the 3 nuts holding the downpipe to the turbo? I have doused them in WD all week but they will not budge. Due to lack of space I can only use a short bar on the socket which is the main issue I guess. Looking through various posts there’s suggest using a long extension bar and accessing the nuts from underneath the car, but again there is no straight access that I can see!
Any ideas?
Post #763615 15th Mar 2019 2:46pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
WD40 is a relatively useless penetrant, even their “penetrating” oil is not that good. Get a better pentrating oil like liquid wrench, or use heat.
Good luck. Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #763634 15th Mar 2019 4:27pm
excossack
From memory, I accessed mine from underneath with a long extension and a flexible knuckle with a 13mm socket. Maybe it would work better with a hot exhaust (but don't burn yourself) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #763636 15th Mar 2019 4:31pm
bankz5152
Bolts on mine needed a 19mm spanner!
Use a spanner. Smack it with a hammer.
Use Plusgas.
Post #763665 15th Mar 2019 6:29pm
Mdm
tyr getting the engine hot
try real penetrating oil. any of the good brands are ok.
try freeze sprays after heat
wd40 isint any good for much on a lr these days
we use long extensions and get them from ground level
and heat if you have access to oxy acetylene
good luck
Post #763692 15th Mar 2019 8:13pm
excossack
Use Plusgas.
My bad, yup 19mm would be more like it 1999 Defender TD5 110
Regards
John M0VAZ
Post #763751 16th Mar 2019 9:50am
Emptywallet
Thanks everyone.
I have tried and failed using all the above methods other than oxy acetylene. My little gas blow torch is like Peeing in the wind with so much iron around to soak up the heat. All I have managed to do is round off the nut a little (15mm on mine). Looks like it will have to book it in to a professional.
Post #763951 17th Mar 2019 11:34am
Screbble
How did you get on in the end Emptywallet? I hope you got it sorted.
Does anyone know the thread size/pitch for said studs on the turbo to down pipe connection, as in anticipation of doing the same job myself shortly, I'd ideally like to be prepared with 3 new nuts.
I think the std nuts are steel flange head but I'll probably be opting for brass/copper full nuts.
Post #772205 8th May 2019 10:22pm
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I used 2 half inch drive extension bars joined together on the nut most inwards towards the engine from underneath with a small Dewalt impact gun. For the other 2 I managed to get the impact gun in from the top around the manifold. Loosen off the one nearest the block first as its the hardest to get onto. I think one bar was a foot long and another about 4". Did this last week, I removed the gearbox crossmember to do the job as well.
And yes WD40 penetrant is rubbish.
Post #772224 9th May 2019 7:45am
gtmotorsport
United Kingdom 2006 Defender 110 Td5 CSW Zermatt Silver
I was in a similar situation a few weeks ago and resorted to cutting my original down pipe to allow my to remove the turbo and manifold from the top. Being prepared for the worse I pre-ordered all new studs and nuts for the turbo and resorted to slicing down the side of each nut holding the down pipe on and then replacing all the studs, etc.
I realise a little extreme of an approach, but I had various attempts previously and failed. I also fitted a de-webbed and skimmed manifold at the same time in addition to renewing the manifold / head studs and nuts (Wurth kit).
Post #772230 9th May 2019 9:05am
Emptywallet
Screbble I hate to admit it, but I gave up and got a local garage to sort it. It took them 2.5 hours and was an absolute b@st@rd!
End result is worth it though. I also removed the centre box and had a Stage 2 remap from Storm. Car sounds lovely and not too loud. Performance is also in a different world now. It is not fast by today’s standard (why would I want it to be) but is far more flexible and a lot less terrifying when joining motorways, etc.
Post #772270 9th May 2019 1:26pm
Screbble
Glad the end result was worth it Emptywallet Thumbs Up
I don't blame you for letting someone else enjoy the pain.
Gtmotorsport - do you recall the thread size of the 3 studs/nuts securing the turbo to the down pipe?
Post #772347 9th May 2019 7:33pm
gtmotorsport
Screbble - If I recall correctly they were a stock M10 threads as I had to drill and re-tap them on the turbo. I purchased genuine suds, but they certainly aren't cheap as studs go.
Post #772380 9th May 2019 9:20pm
lightning
My studs came off fine but what a job to get the downpipe out between the engine and chassis! The old one seemed to fiddle out quite quickly but l spent ages trying to get the new (genuine LR) one back in and it just wouldn’t fit through. There’s obviously just one place that it fits.
Eventually and near to tears of frustration l used a scissor jack to move the engine very slightly and after another twenty minutes of messing about it finally went through the gap.
Post #772729 12th May 2019 8:43am
