![]() | Home > Maintenance & Modifications > Optimill Quick Release Fitting |
X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212 ![]() ![]() ![]() |
I fitted one a couple of weeks ago without issue, I think I used a 22. Used the same nut that I look off.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
I have never had a problem fitting a socket on the nut. It may be that your socket is too thick-walled (cheaper sockets are often have a larger outside diameter than higher quality ones).
If you really can't find a socket that fits, then consider buying a box spanner of the right size. These are generally much thinner-walled, something like the link below but check the size of course. https://www.amazon.co.uk/d/Socket-Wrench-S...ref=sr_1_4 I really wouldn't advise trying to change the nut, and you may well find that it is not a common thread on the top of the column. Last edited by blackwolf on 13th Mar 2019 1:47pm. Edited 1 time in total |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2540 ![]() ![]() ![]() |
Fitted Optimil QR boss a couple of weeks ago with no problem (48 spline though). Defender 90XS SW
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1889 ![]() ![]() |
Unless someone's changed the nut already, to something non-standard? I know I didn't have any issue at all fitting mine.
I think pics are going to be needed here. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5981 ![]() ![]() |
Sounds more like you need a thinner walled socket. Is that the problem?
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10384 ![]() ![]() |
Another spare thing I have in my garage
![]() ![]() Yup, try a thinner wall socket. QRZ 2e0vpf |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 ![]() ![]() ![]() |
If I remember correctly, mine was a 24, and it was a snug fit, but a long socket fit just right.. I did mine hand tight plus a 1/4 turn Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
MetalMatt Member Since: 29 Jul 2016 Location: West Yorkshire Posts: 180 ![]() ![]() ![]() |
Cheers for all the replies,
I have managed to nip out on my lunch break and get some photos of the nut. How thin do sockets go ![]() Does this look to be the wrong nut? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 1995 Land Rover Discovery 300tdi - Sold 1989 Land Rover 90 - Rebuilding/built - its a project 2002 Land Rover Discovery TD5 - Sold 2017 Mini JCW F56 - Current Daily Driver |
What age is your vehicle?
Your nut is clearly a different size to to that on my 2007 Puma:- ![]() Click image to enlarge In the parts list, this nut (for a 2007 vehicle such as mine) is described as "NUT - HEX., 14MM, METRIC", part number QYH500130. If it is a standard M14 (ISO 4032 coarse series) nut, the AF dimension is 21mm. I do not have a 21mm socket with me, but I can say that a 22mm socket is a slightly loose fit and a 20mm socket won't fit, so it would appear that it is most probably a standard M14 nut. Prior to chassis (V) MA962814 this nut is "NUT - HEX., UNF, IMPERIAL, '1/2"', STEERING WHEEL" part number CRC2015. A 1/2 UNF nut to SAE-5 B18.2.2 will have an AF size of 3/4" (19.05 mm), which is clearly smaller than an M14. So on the fact of things you seem to have a non-standard nut on your column! |
My 90 is a 1989 model...... so am guessing it is probably going to be an imperial sized nut and just found online a PDF parts list for a 1987 year 90 which says the part code is CRC2015.
Looking at yours i am going to agree mine is a non standard nut (even though yours is a 2007 it still has room to get a socket around it ![]() 1989 Land Rover 90 - Rebuilding/built - its a project 2002 Land Rover Discovery TD5 - Sold 2017 Mini JCW F56 - Current Daily Driver |
WOW that's a big nut, way bigger than mine - sad to say ![]() ![]() ![]() Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Fitted one last week. Standard 22mm socket set fit perfectly.
Mine is a 2.2 puma. Not that it helps, but you have one whopper nut! ![]() Click image to enlarge |
Well the mystery continues, ordered a new nut CRC2015 which is specified on the PDF parts list i found and also what Blackwolf put in his post.... It arrived today put it on the steering column and its exactly the same size as the one that was already on in the above photos. Got a socket out to check the sie and its a 27mm socket that fits the nut.
Any ideas? If not i am going to remove the column and stick it up the landys exhaust lol 1995 Land Rover Discovery 300tdi - Sold 1989 Land Rover 90 - Rebuilding/built - its a project 2002 Land Rover Discovery TD5 - Sold 2017 Mini JCW F56 - Current Daily Driver |
Just checked the QR boss I fitted a couple of weeks ago. I used a standard 22mm AF socket, definitely not thin walled.
A standard M14 nut should have a cross flat dimension of 20.67 to 21.0mm. Can you not locate a M14 nut locally and try that? Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
