Home > Wheels & Tyres > Michelin 235/85 R16 (120) S LATITUDE CROSS |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 |
hmmm looks like kwik fit only fit tyres they sell, is that a general rule then? I have 4 tyres in the back lol
JD 2008 TDCi 2.4 XS CSW |
9th Mar 2019 4:40pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4430 |
Fitted four of these to the 2008 Puma last week. They replaced Continental Contitracs which are no longer available in 235/85/16. The Michelins are very quiet. I never regarded the Contitracs as noisey but the Michelins are really quiet.
I find with the way the Land Rover is set up engine power delivery wise coupled with the gearing and permanent four wheel drive, basic AT tyres will get you most places. In this 2008 Puma which origionally had General Grabber TR tyres fitted then Continental Contitracs I managed with snow and floods. Even frozen snow provided you don't try to climb a 1 in 1 gradient. Braking on frozen snow is the big one. Just drive to the conditions and gentle cadence braking will see you through. Granted if you need an emergency stop and hit the brakes on frozen stuff you will slide but this will happen no matter what tyres you have. The snow flake will probably stop you a little quicker. The off road side of things is O.K. too. I never had a problem with AT's in tyre deep mud or clag, i.e. from the bottom of the tyre to the rim or above it. The price was £130 per tyre fitted and balanced 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
12th Mar 2019 11:21am |
Had mine fitted yesterday......they look great and are soooooo much quieter than the GG TR's, a big difference in noise level.
12th Mar 2019 3:08pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 904 |
Sounds good
Bit the bullet and ordered mine today from black circles and booked to be fitted at local ATS next week. |
12th Mar 2019 3:36pm |
962JOF Member Since: 26 Jan 2019 Location: Oxfordshire Posts: 18 |
Mine were Blackcircles and fitted at ATS Euromaster - I’ve had them a month now and been very pleased with them - fine in all this rain and standing water too. I’m glad I went for these. Producer / glasses-wearer / Londoner (& er Oxfordshire) 🎬 👓 💂♂️
12th Mar 2019 6:19pm |
Some pics if interested.....
Click image to enlarge Click image to enlarge Click image to enlarge JD 2008 TDCi 2.4 XS CSW |
13th Mar 2019 7:58am |
13th Mar 2019 8:06am |
13th Mar 2019 8:08am |
Had mine fitted today, pleased with how they look, and more importantly, the better drive compared to my old worn trs
What pressures are you chaps running these on? Thanks Mike |
19th Mar 2019 3:46pm |
I run 28 psi in front and 35 psi at the rear. This is listed by Land Rover as the "comfort" mode. If you are using the Land Rover fully loaded or towing a heavy trailer to go to 48 psi in the rear. For everyday life the 28/35 psi combination is fine as it is hard to overlaod a Defender as a family car. It's the towing you need to watch.
Just checked and Land Rover say you can go to 32 psi at the rear for everyday use but I've always run at 35 psi. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
19th Mar 2019 5:36pm |
Thanks
19th Mar 2019 6:58pm |
