![]() | Home > Maintenance & Modifications > Soft A Bar Light sizes |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 170 ![]() ![]() ![]() |
9” fit just
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
I’ve got Cibie 9” LED super oscars and they fit spot on 👍
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2667 ![]() ![]() |
Lazer rs8 fits nice,
I had a longer Chinese bar in there in the past, output was a lot less than the smaller Lazer bar tho. |
2010Blackdefender90 Member Since: 07 Jan 2018 Location: London Posts: 562 ![]() ![]() ![]() |
Thanks everyone
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 25 ![]() ![]() ![]() |
Hi,
And what should be the best harness for this lights in the A-Bar? any reference and supplier for the harness to mount it? |
I have used a Lazer harness, which is pre-wired, on to the LED, so any should be fine to match your make of lights, with the right water tight connections
Yup, I had a light force loom in from when I had spots, carried this over with my Chinese lighter
when I installed all the laser products I used there specific wiring harness. the RS8 had a few more cables, the triple R on the roof is a fairly high output LED |
Hi,
Does anybody know the weigth of each light that can the soft A bar can support? I have the LR006415 to mount but I want to hang up on the A bar the lights. What is your opinión? Thanks, |
