Home > Puma (Tdci) > Camshaft Carrier leak
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Has anyone had a leak from the join in their Camshaft Carrier? Mine is leaking and I'm trying to figure out why it would start leaking. My local 4x4 garage had a look and confirmed its the carrier joint (not rocker, head, vacuum pump etc) but said they have never seen one leaking and unsure of what would cause it.
Any ideas?
Post #762511 8th Mar 2019 3:21pm
Mine's had a very slight leak (over the front branch of the exhaust manifold) for at least the last 9 years. It's not bad enough to bother about, but I don't think that it's unusual.
Post #762532 8th Mar 2019 6:13pm
boxoftricks
Ahh that’s good to hear that it’s drivable. Do you know if you can just carefully remove the carrier leaving camshaft and everything else in place? Im guesssing I need to tension off the timing chain? Then clean up and reseal?
Post #762541 8th Mar 2019 6:23pm
I believe the camshafts have to come out before the carrier can be removed from the head.
Post #762575 8th Mar 2019 8:50pm
