Home > Technical > Ecu Reflashing
MK
Ecu Reflashing
Please, a few questions to those with immense knowledge on 2.4 TDCI
Why would you need to reflash the PCM (is it ECU, ECM OR PCM?) ?
Is it compulsory to do it with the SDD and online?
What in the PCM could lead to a failure in the process? is it straight forward if you have the necessary software and hardware and if you know wht you are doing?
Many thanks in advance Bow down Puma 110" SW
Post #762454 8th Mar 2019 12:18am
