Home > Maintenance & Modifications > Best DAB Ariel?
PCM
Best DAB Ariel?
Recently upgraded my standard stereo for a double din and added a DAB splitter to the existing Ariel.
This was rubbish.
Then I added a window mount one. Much better, but still not as good as any normal car andbstruggles to get FM or Dab in some areas.
What brand and model of Ariel do people use that actually works!
Post #762342 7th Mar 2019 3:55pm
JOW240725
I can't really help but all I would add as a recent convert to DAB (in my company eurobox) is I've been suprised how bad the digital signal is over large swathes of the countryside.
Also forum sponsor Brendan had an offer on recently on the Nakawhatsitcalled aerial https://www.defender2.net/forum/topic65245.html?highlight=dab James
Instagram @suffolk_rovers
Post #762347 7th Mar 2019 4:10pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
I just added a powered splitter to the factory OEM aerial when I fitted my Pure Highway DAB radio, works a treat, no complaints at all Thumbs Up
Edited to add - This one -
https://www.dynamicsounds.co.uk/autoleads-...itter.html
Post #762351 7th Mar 2019 4:34pm
Tilly
United Kingdom 2010 Defender 110 Puma 2.4 USW Indus Silver
Same here using a powered splitter. Never had any signal loss using the standard aerial.
Post #762353 7th Mar 2019 4:48pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
The only way I have managed to get decent broadcast radio reception in my defender is to use a roof rack mounted antenna on DAB.
The fm wing aerials I have tried have always been variable in their ability (not tried the Nakatenanga one) and after a few weeks just seem to stop working full stop. Stick on window ones have been utterly hopeless either on FM or DAB.
I switched to a DAB head unit with one of the mini magmount DAB antennas which was great until it got knocked off and the cable broke.
The solution came in the form of a short amateur radio 1/4 wave type non loaded antenna and a proper bolt on roof rack mount. It is relatively solid and works (although it does prune low trees like all the antennas on my roof rack). One thing I would say is that it is an expensive way of doing it but has outlived everything else. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #762362 7th Mar 2019 5:21pm
PCM
I must live in a rubbish signal area as the town centre is fine, but near my house is just awful.
Only concern is all other cars work great.
Mine can’t get anything but static on dab and FM.
Anyone used the nakatanakaka..... one?
Post #762367 7th Mar 2019 6:06pm
It can vary a lot purely on signal where you are rather than the aerial equipment you have but both have a bearing on each other of course.
I found on mine with the original aerial even FM was rubbish never mind DAB.
I have the Naka Aerial kit, but won't be fitting it for quite a long time yet and don't have a DAB capable HU just yet either.
Plenty have bought them and fitted here so shouldn't be long before someone is along.
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #762384 7th Mar 2019 7:45pm
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
I have a nakajobby one being fitted on the wing next week, I currently use an external halfrauds one, so can compare once it comes back Thumbs Up
Post #762438 7th Mar 2019 10:22pm
Look forward to it. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #762444 7th Mar 2019 10:45pm
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
I would just like FM radio mine's all over the place some days good other no reception is it the radio or the aerial both standard Land Rover
Post #762452 8th Mar 2019 12:04am
You could fit a booster, the Naka Aerial allows you to use just FM or DAB or both combined.
On factory HU you can use DIN FM with the Naka Aerial no problem.
Just Earth and power it from another source and it'll boost it, the factory Aerial is not boosted.
Most vehicles these days are as boosted as standard.
You can even boost the factory Aerial if you wanted. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #762455 8th Mar 2019 12:32am
legin
Thanks Steve I will see about a getting a booster fitted.
Post #762467 8th Mar 2019 9:18am
PCM
Spoke to auto engineer and they reckon the fault with mine may be a dodgy USB charger in the place of the cigarette lighter.
This is a blue sea one so i’m Doubtful...
Will see but for now not going to spend £80 on another antenna.
Hmmm...
Post #762482 8th Mar 2019 10:51am
Mo Murphy
I have a blue sea usb, when used it certainly interferes with fm reception. I was pointed in this direction by fellow forum members when I queried the performance of the older type nakatanenga aerial.
I don't know about DAB as I don't have it, I'm afraid.
50 Shades of Pennine Grey
Post #762487 8th Mar 2019 11:45am
PCM
Mine causes interference (maybe) when not in use. Just simply by being there.
Will see later when I get the dash off and remove it.
Post #762491 8th Mar 2019 12:05pm
