![]() | Home > Td5 > Galvanic corrosion problem with TD5 fuel filter head |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Mine failed a few years back just like that. I initially considered the GORE version but ended up getting the original LR replacement. However, before fitting it I gave it several coats of a thick 2-pack epoxy paint designed for chassis use with the expectation of it insulating the cast alloy from the steel chassis & fasteners.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3260 ![]() ![]() |
It’s a fairly common failure due to the position of the filter under the rear wheel arch.
I cost mine with spray grease every so often and it seems fine so far. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2217 ![]() ![]() ![]() |
At that stage the head may well have become porus id replace it.
have order replacement ££££££ ***!!!!!! and use isolation on new one
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 980 ![]() ![]() ![]() |
FWIW and some food for thought... I wrap all stainless bolts and dissimilar metal bolts in teflon tape to isolate them. It has worked very well for many years now. It is time consuming but worth it. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
