Home > Puma (Tdci) > wiper wheel box :'(
Page 2 of 2 <12
Moneypit
2004 Defender 110 300 Tdi HT Fuji White
Anyone tried the HD stainless steel version available from designdevelopmenteng.co.uk . Spotted them a while ago but there not cheap and want to get a real world review before spending my hard earned.
Post #748966 3rd Jan 2019 8:15pm
I came across those a couple of days ago and wondered much the same. You can buy an awful lot of genuine ones for the price of one of those!
Post #748969 3rd Jan 2019 8:30pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Removing the dash really isn't as bad as people think, I've done it a few times.
One thing I always do is bag the bolts and screws, and write on the bag their exact location, tying them to the part where I can too.
Having done it before I reckon I can get the whole dash out in 30mins now, maybe took me an hour the first time going slow. Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #749441 5th Jan 2019 8:06pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
Take every screw out you see and take a picture of the screw and where it's coming from ( ie take the picture as you're removing it to get an idea.
It isn't a difficult job and with taking pics, it'll be out within 25 minutes easily.
Remember, defenders are designed by their nature to be easily fixed, repaired and stripped.
Don't think it's difficult, it really isn't Thumbs Up
Post #749452 5th Jan 2019 8:54pm
B4Lamb
Wales 2007 Defender 90 Puma 2.4 HT Galway Green
mata wrote:
Ive done this job... TWICE!
First time i'd mistakenly ordered britpart wheel boxes and they didn't last. Second time round i replaced wheelboxes, inner worm, outer tubes and motor gearbox wheels with all genuine LR parts and would absolutely recommend doing the same.
I didn't completely remove the dash, although only because i didn't know how to remove the gearstick at the time. Its a bit of a pain with the dash pulled down and to be honest its probably worth getting it right out, its not much more work, from what i've read since removing the gearstick is pretty quick once you know how.
Thanks Mata I've already bought new wheelbases and an inner cable and it is marked up as Bearmach parts. I'm not sure of the quality but they look well made to me. I wondered about the outers but these do not seem to be as available. I will have to assess whether these need replacing when I get them all out.
I think I will go the whole hog and remove the dash completely, it seems to be worth the effort to reduce the damage to hands and wrists. "You are never to old to learn something new"
Post #749488 5th Jan 2019 11:05pm
Nitroneil
Sad Guess what I have arriving Friday, yip a pair of wiper gearboxes. So I will see how I get on Sat. Any hints in addition to those above would be great (its genuine LR boxes)
Thanks
Neil
Post #762261 6th Mar 2019 11:38pm
B4Lamb
Good luck with it. Just take your time and take lots of pics of where the cable looms are routed as it's easy to foget and route them differently when you reassemble. My wiper cable outers were good so didn't have to replace them. Use plenty of grease up the tubes and on the new cable.
You will need to remove the steering wheel. I didn't use a puller but some heave thumps with a lump hammer on the back of the steering wheel did it bit leave the nut on a few turns to stop the wheel flying off. Its best to disconnect the battery in case you short something out but I did mine live. Give me a shout if you hit a snag, Imay be able to help . I'll keep looking at email notifications.
John "You are never to old to learn something new"
Post #762263 7th Mar 2019 12:39am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Thanks
Neil
I use a syringe loaded with grease (fingers would also work) to lubricate the wheel boxes prior to fitting and the run the worm drive through a few times adding a little grease to ensure it’s all well lubricated.
Whilst the dash is out I would recommend the fitting of twin washers Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #762266 7th Mar 2019 2:41am
Nitroneil
Well thats it sorted, pretty straight forward apart from the heating ducts. Those plastic screw/plug things are a real pain. All back together with Genuine gearboxes, running sweet. One of the old gears had worn away, the drive wire was fine though, cleaned up, greased and back in. Did take about 4.5 hours, not rushing and included a search about removing gearstick, which is stupidly simple. Left steering wheel on though. Posts here were a great help too, thanks.
Post #762678 9th Mar 2019 4:02pm
B4Lamb
I'm surprised you managed without taking off the steering wheel. Conversely I didn't remove the gear stick as I didn't that was necessary. I wanted the steering wheel off anyway as I needed to reset the indicator cancel position that had been offset during a previous garage repair of the ignition switch. I found that the peg that engages in the cancelling ring has a rubber sleeve over it that had split so not only was the cancel not symmetrical either side from straight ahead there was also steering rotation before the peg started moving. I added some heat shrink sleeve over the rubber coated peg and it has made indicator cancel so much better. "You are never to old to learn something new"
Post #764044 17th Mar 2019 7:52pm
Nitroneil
i did have the guages and steering cowl off and that gave me enough room to work at gearbox, had to remove some heater duct but managed. Really didnt want to completely remove dash. Usually find if steering is out of staight its the balljoint at the steering bars that needs adjusted. Unless of course someone has had it off before and put it on squint.
Post #764096 18th Mar 2019 12:22am
Page 2 of 2 <12
