![]() | Home > Maintenance & Modifications > OME Spring Choices |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4317 ![]() ![]() ![]() |
I’ve no idea what to recommend, but this might be of use f you haven’t seen it already http://www.red90.ca/rovers/springinfo.html 2007 110 TDCi Station Wagon XS
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2490 ![]() ![]() ![]() |
Talk to gwyn lewis.
I dont think it is a good idea to have a loaded 110+2 inch lift+ soft suspension. Puma 110" SW ............................................................. Earth first. Other planets later |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2225 ![]() ![]() ![]() |
Cheers. Good info
I didnt say soft, just softer. The ride is rock hard persey but driving down bad roads you can feel the potholes and speedbumps, becomes quite tiring after a while. Also considering fitting a rear ARB as i do more rosd driving now than off. |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
751 on the front
![]() I have about 100kgs over std on the front of mine, as yet no sagging after 4years. 2004 TD5 Defender 90 xs station wagon |
Sweet so 751 on the front just to work out the rear
