Home > Maintenance & Modifications > 2 Post lift and the Defender
apachecow
1999 Defender 110 Td5 CSW Rutland Red
Guys
Any advice? Anyone use a 2 poster on a Defender?
Looking like I need to buy one for my Discovery (body off), and use on other vehicles would be a bonus.
Where do you lift? Is she front heavy?
(110 TD5 CSW)
Thanks
Post #761779 3rd Mar 2019 10:36pm
AndrewS
I stick my 130 on a two poster no issues Thumbs Up 130's have feeling's as well you know Smile
Post #761789 3rd Mar 2019 11:27pm
landy andy
Your Defender weighs a lot less than your Discovery if you are planning on lifting the entire thing at any point
Post #761791 3rd Mar 2019 11:30pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've lifted mine (2014 110) many times on a four ton one with no problems.
Post #761799 4th Mar 2019 7:05am
apachecow
Thanks guys. I realise Defender much lighter.
Underneath on the D3 are steel chassis rails giving lots of jacking options. Wondering where to lift the Defender.
Is she very front heavy?
Post #761915 4th Mar 2019 8:03pm
grafty99
My 90 goes on my ramp regularly for cleaning and servicing.
Front points under the radius arm chassis mounts and the rears on the trailing arm chassis mounts.
Steady as a rock Thumbs Up
 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #761923 4th Mar 2019 8:47pm
apachecow wrote:
...Underneath on the D3 are steel chassis rails giving lots of jacking options. ...
I think you'll find some pretty sturdy chassis rails under your Defender! Rolling with laughter
Post #761924 4th Mar 2019 8:57pm
Martyn668
.....unless the rustworm has bitten. Not so sturdy then. To be fair, as far as I know, mine are fine. (Tempting fate). I guess it's usually the rear cross member and the outriggers that go first.
How come RRC chassis never had the same problem? Pretty much surface rust only with them wasn't it?
Post #762196 6th Mar 2019 6:21pm
